Hello, I would like to ask that I use jetson nano (linux18.04) jetpack (4.2.3) version, my cuda (10.0), but cuda displays NOT_INSTALLED when I am doing sudo jtop.
I tried export CUDA_HOME=/usr/local/cuda-10.0/
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64:$LD_LIBRARY_PATH
The method of export PATH=${CUDA_HOME}bin:$PATH failed in the end. There is no data file for bin and nvcc. How to solve the above problem, thank you
