Linux > arm64-sbsa > Native > Ubuntu > 18.04 > deb(local)
By downloading this errror came > Broken Packages
after that,
Linux > arm64-sbsa > Native > Ubuntu > 18.04 > runfile(local)
wget https://developer.download.nvidia.com/compute/cuda/11.6.2/local_installers/cuda_11.6.2_510.47.03_linux_sbsa.run
sudo sh cuda_11.6.2_510.47.03_linux_sbsa.run
I installed it successfully so that which I give ncvv -V I can see the result
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Tue_Mar__8_18:19:06_PST_2022
Cuda compilation tools, release 11.6, V11.6.124
Build cuda_11.6.r11.6/compiler.31057947_0
But if I try command : which nvcc the result is null
To rectify this I tried commands :
ls /usr/local/cuda*
/usr/local/cuda-11.6/bin to $PATH or export PATH=/usr/local/cuda-11.6/bin:$PATH
/usr/local/cuda/lib64 to $LD_LIBRARY_PATH
but a result it showed bash: /usr/local/cuda-11.6/bin: Is a directory
Please install through SDKManager. It’s included in SDK components.
Respected Sir, @DaneLLL
By installing through SDKManager I need to put Jetson Nano in Recovery Mode can I use the command $ sudo reboot –-forced-recovery
The command should work. Another way is to short the pins on J14. Please refer to developer kit user guide:
https://developer.nvidia.com/embedded/dlc/Jetson_Nano_Developer_Kit_User_Guide
Respected sir, @DaneLLL
Thank you so much for your help, and my query is not a one-day process I have just started this step, and in this journey, I will try to complete step by step. Once any thank you for your will again contact you for further queries.
Yours Respectfully
Shrijayan
Top logo designing and web development company in Erode and Coimbatore one of the best web design company in Coimbatore,offers web designing, branding, best seo, logo designing, website redesigning, website maintenance, single color printing,...
Est. reading time: 5 minutes
system
Closed
May 25, 2022, 1:24pm
6
