I am a little confused when I read this message:
Do I should assume that in newest Jetpact this problem is resolve so I can use eMMC on SDMMC3?
No, we donât support extra emmc on sdmmc3.
No such case before. Only sdcard.
BTW, I also not quite understand why this post would confuse you.
I wrong understood you. I understood that better is use eMMC on my carrier board than uSD card. But now I assume that you thought about eMMC on SOM.
The most problem is that I need eMMC at least 32GB. The target solution is use SOM with eMMC 16GB and extra eMMC 32GB on carrier board. But now we must change solution to uSD card on carrier board.
I want to report solution for this topic. When I use SOM which contain eMMC then I didnât have any problem with configuration (I use device tree configuration from above messages)
