Hello, I’m using a Jetson Nano Developer Kit 4GB. At first boot, the NVIDIA logo pops up and I get the following error. I used JetPack 4.6.1, and I’ve reflashed it for several times using balena Etcher and Rufus, but I get the same error everytime. SD Card is using Sandisk Ultra 64GB. Help!
Please get the native ubuntu 18.04 and install sdk manager to full flash your device.
If you have other version of ubuntu, you could install bsp and sample rootfs and flash it manually.
Thank you for your answer. After Flash, I checked in the disk management window and found that the partition was not properly divided, will it work out if I follow the way you said it??
