Jetson Nano Flashing failure
Hi Jetson experts,
We bought a new batch of Jetson Nano boards but Flashing failed.
Here is the brief descriptions of the issue and background.
Starting at byte 20 in the eeprom there is supposed to be a string in format 699-cnnnn-pppp-vvv. On this batch of modules it has a string “699-13448-0004-002”, but according to official documentation below (See Link) that is not a valid string for this product, so the flashing script is failing. 3448 is correct for Jetson Nano, but 0004 is not, it should be 0002. 0004 Is listed as ‘Jetson AGX Xavier (32 GB)’ which these are definitely not.
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3276/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/jetson_eeprom_layout.html#
Can you please help?
Thanks,
Hi @Pxnask ,
This appears to be related to an issue reported with a newer batch of Jetson Nano modules using the same EEPROM part number (699-13448-0004-002).
In this thread, an NVIDIA representative acknowledged a possible issue with this batch and recommended contacting the distributor to report the problem and arrange replacement modules:
I would recommend contacting your distributor and referencing that discussion. Since the SKU is not documented for the Jetson Nano, I would avoid manually overriding the EEPROM values until NVIDIA confirms whether this is simply an identification issue or involves hardware changes.
Hope this helps, best regards!
Arrow EU reported this issue first, and there are some modules shipped to customer already.
Currently this issue was fixed and created the lesson learn in our factory side(ODM partner).
Please do the swap with distributor or reach out to your Nvidia representative.
