Jetson nano flash:command terminated with error
after apt-mark hold, change value of 0x10 registor of I2C bus 1. the jetson system can not work. flash failed . what can ido
Please click the export logs from sdkmanager GUI to share the whole log.
It may not help much to share just a screenshot. Also, is your host machine a VM? Sdkmanager does not support on VM.
this is the log, thank you
SDKM_logs_JetPack_4.5.1_(rev._1)_Linux_for_Jetson_Nano_2023-01-30_13-27-57.zip (125.2 KB)
SDKM_logs_JetPack_4.6_(rev._3)_Linux_for_Jetson_Nano_modules_2023-02-02_17-50-54.zip (55.1 KB)
This is Jetpack 4.6 log , thank you
You messed up your module eeprom so flash script does not let you flash.
Is your board still able to boot up?
Same issue as this one
SDKM_logs_JetPack_4.6_(rev._3)_Linux_for_Jetson_Nano_modules_2023-02-02_19-03-15.zip (83.4 KB)
my board is A02, the sdkmanager shows jetson nano. however, the process still failed. please check the log
No, I know you cannot flash the board. I already explained the reason in previous comment…
I may not express myself clearly. I know what you mean. I just used b01 image to burn A02 board only once, the log is SDKM_logs_JetPack_4.6_(rev._3)_Linux_for_Jetson_Nano_modules_2023-02-02_17-50-54.zip. THIS was a just try after I used sd card method, source code compilation method and image method. After I changed I2C Value of register address(BUS 1 11 ADDRESS) using I2C detect tool, my board can not boot up. Source code compilation method failed, but code compilation method can flash before change I2C value. Attached are pictures and log. I have check the Jetson Nano A01
So please refer to the above posts I shared…
所以麻煩參考我上面貼的那篇post…
I think the change of register value caused the board model mismatch. How can i reset all value of registers or use SD card boot?
I already told you the cause of this issue in above comment… your issue comes from you ruined the eeprom value when doing any kind of i2c work…
