Jetson nano ModuleNotFoundError: tflite-runtime
I am using 18.04 ubuntu version on jetson nano. Python 3.8 , tensorflow 2.5.0. When I run the file with .py extension in the terminal, I get the error shown below.
File “./follow.py”, line 6, in
import tflite_runtime.interpreter as tflite
ModuleNotFoundError: No module named ‘tflite_runtime’
How can ı fix the problem? What are the possible solutions?
Based on the error, you will need to install tflite_runtime.
I did the installation as you said. However, I get the error below. When I download the Wheel package, I get the same error even when I install it. Install TensorFlow 2 Lite on Jetson Nano - Q-engineering Although I do the operations on this site one by one, I get the error that it does not support. When I run my Python file again, I continue with the same error. I have been dealing with this problem for 2 days but I still haven’t gotten any results. I am using 4.1.1 as OpenCV.
By the way, the package I use is jetpack version 4.6. How can I solve this problem?
The error is shown in the jpeg file.
The package is not built for Jetson.
Usually, you will need to build it from the source.
Or you can check with the library owner to see if they have provided a prebuilt package for the Jetson environment.
