I’m trying to communicate with a device (an IMU) via serial, but I’m not able to open the port. I’m getting the following error returned from the PySerial Python Module:
Error: Could not configure port: (25, 'Inappropriate ioctl for device')
My IMU is plugged directly into a Jetson Nano USB 3.0 port. Here’s the output from dmesg:
[11562.545478] usb 1-2.1: new full-speed USB device number 12 using tegra-xusb
[11562.567294] usb 1-2.1: New USB device found, idVendor=2639, idProduct=0002
[11562.567302] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[11562.567307] usb 1-2.1: Product: MTi-20 VRU
[11562.567312] usb 1-2.1: Manufacturer: Xsens
[11562.567317] usb 1-2.1: SerialNumber: 026001B1
So the device is being found, but it’s not being assigned to a ttyUSB* port. Here’s the output from ls -l /dev:
lrwxrwxrwx 1 root root 15 Sep 18 17:26 IMU → bus/usb/001/012
On computer with the device working properly the following is returned from dmesg:
[25131.692211] usb 1-2: new full-speed USB device number 15 using xhci_hcd
[25131.841470] usb 1-2: New USB device found, idVendor=2639, idProduct=0002
[25131.841475] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[25131.841478] usb 1-2: Product: MTi-20 VRU
[25131.841481] usb 1-2: Manufacturer: Xsens
[25131.841484] usb 1-2: SerialNumber: 026001B1
[25131.842719] xsens_mt 1-2:1.1: xsens_mt converter detected
[25131.843138] usb 1-2: xsens_mt converter now attached to ttyUSB0
and ls -l /dev (I didn’t bother to set up udev rules on this computer)
crw-rw---- 1 root dialout 188, 0 Sep 18 17:29 ttyUSB0
Could anyone point me to a driver or something that I may be missing?
Edit: I did some more digging and I’m pretty sure I’m missing a driver for this cable that I’m using to connect to the device. From the MFG website this is stated:
If you are using the MTi with the standard USB cable (CA-USB-MTi) (i.e. without a USB to serial converter) the correct drivers have to be installed.
For Windows:
Make sure to have WinUSB installed.
For Linux:
libusb is included in the latest Linux kernel (Ubuntu).
In case the MTi is not recognized, visit https://github.com/xsens/xsens_mt to install the driver manually (e.g. on some versions of embedded Linux).
Does anyone know if libusb is included with the Jetson Nano or how to install it if it is not?
