When I use :
modetest
There are no any infomation for DRM
And then, I try to use drm_info:
drm_info
So, does the jetson not achieve the standard DRM Framework?
If you are asking for direct rendering manager, we have the sample in jetson_multimedia_api. Please check
Jetson Linux API Reference: 08_video_dec_drm (Direct Rendering Manager) | NVIDIA Docs
Thank You! I am trying to solve a DisplayPort(DP) driver problem.
I am adapting kernel-6.6 for jetson, and DP connector and GPU work fine, except for one small issue:
When I plug the DP interface before system boot, the screen will show the kernel log, and disappeared at X window runing。
I am not sure whether the kernel driver(DRM) has problem,so I want to test how each part works to determine what the problem is.
I’ve found that tegra’s DRM implementation is different from the usual, it doesn’t have connectors, panels, etc.
Thanks, this helped me a lot!
You should be using Jetson Orin Nano instead of Jetson Nano. Please check the document for Orin Nano:
You can install the samples through SDKManager or apt-get install command.
I’m trying to determine if there is a DRM driver issue or if X11 has to be the problem. Is there a good way to determine that?
If the DP is inserted after system boot on, it is displayed normally. If you plug in the DP before booting, it will only show the kernel log, and then there will be no DP signal when you enter the desktop.
There is syslog for DP plugged before booting:
syslog.log (267.6 KB)
and I can not find any error for display.
Please try Orin Nano developer kit with default Jetpack 6.1(K5.15). To ensure it can be run successfully on the setup.
