Orin nano doesn't booth with DP cable plugged in, but works if DP cable is connected after the boot
I have a Jetson Orin Nano 8Gb dev kit that I set up with JetPack 6.2.1 installed following the microSD-only setup process described here
mksergey@jetson-nano:~$ sudo apt-cache show nvidia-jetpack | grep Version[sudo] password for mksergey:
Version: 6.2.1+b38
Version: 6.2+b77
Version: 6.1+b123
This was done with an external monitor, keyboard and mouse attached.
Now, when I try to boot the nano connected to a different, ultra-wide monitor when the DP cable is attached the nano won’t boot. The screen is “on“ but blank and I don’t see nano come up on my network, so I cannot ssh into it.
If, however, I disconnect the DP cable, let the nano boot and then connect the DP cable after the nano comes up on my network everything works fine. I can see the image on the monitor with 2560x1080@60 resolution just fine. So, something at boot time prevents it from loading when the monitor is connected through the DP cable.
Note that I don’t have this issue when I connect it to a different monitor.
Output of dmesg below.
mksergey@jetson-nano:~$ sudo dmesg | grep -i "display\|hdmi\|resolution\|mode"
[    0.000000] Machine model: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.124728] iommu: DMA domain TLB invalidation policy: strict mode
[    0.173015] kvm [1]: VHE mode initialized successfully
[    4.820445] serial-tegra 3100000.serial: RX in PIO mode
[    4.820451] serial-tegra 3100000.serial: TX in PIO mode
[    9.199256] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    9.557253] systemd[1]: systemd 249.11-0ubuntu3.17 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    9.964475] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[   10.279252] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[   11.289277] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[   11.290288] dce: tegra_dce_probe:245  Found display consumer device
[   11.360763] nv_platform 13800000.display: Adding to iommu group 32
[   11.377228] platform 13800000.display:nvdisplay-niso: Adding to iommu group 33
[   11.973566] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[   11.976702] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input5
[   11.976799] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input6
[   11.976933] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input7
[   12.003185] fusb301 1-0025: fusb301_set_mode: mode (32)(32)
[   12.004361] fusb301 1-0025: mode[0x20], host_cur[0x02], dttime[0x00]
[   16.534659] device usb0 entered promiscuous mode
[   16.544407] device usb1 entered promiscuous mode
[   22.541225] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  540.4.0  Release Build  (buildbrain@mobile-u64-6354-d6000)  Thu Sep 18 15:33:51 PDT 2025
[   22.877658] [drm] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
[   22.879405] nv_platform 13800000.display: [drm] Cannot find any crtc or sizes
[   58.342787] nvidia-modeset: ERROR: GPU:0: Failed to allocate 2743000 KBPS Iso and 4294967295 KBPS Dram
[   58.342797] nvidia-modeset: ERROR: GPU:0: Unexpectedly failed to lock to max DRAM pre-modeset!
[   58.404226]  kdispInvokeDisplayModesetCallback_KERNEL+0xd0/0xf0 [nvidia]
[   70.989823] nvidia-modeset: ERROR: GPU:0: Failed to allocate 2743000 KBPS Iso and 4294967295 KBPS Dram
[   70.989828] nvidia-modeset: ERROR: GPU:0: Unexpectedly failed to lock to max DRAM pre-modeset!
[   71.498138] nvidia-modeset: ERROR: GPU:0: Failed to allocate 2743000 KBPS Iso and 4294967295 KBPS Dram
[   71.498145] nvidia-modeset: ERROR: GPU:0: Unexpectedly failed to lock to max DRAM pre-modeset!
[ 1594.704553] nvidia-modeset: ERROR: GPU:0: Failed to allocate 2743000 KBPS Iso and 4294967295 KBPS Dram
[ 1594.704561] nvidia-modeset: ERROR: GPU:0: Unexpectedly failed to lock to max DRAM pre-modeset!
[47861.694119] nvidia-modeset: ERROR: GPU:0: Failed to allocate 2743000 KBPS Iso and 4294967295 KBPS Dram
[47861.694128] nvidia-modeset: ERROR: GPU:0: Unexpectedly failed to lock to max DRAM pre-modeset!
[52286.610314] nvidia-modeset: ERROR: GPU:0: Failed to allocate 2743000 KBPS Iso and 4294967295 KBPS Dram
[52286.610321] nvidia-modeset: ERROR: GPU:0: Unexpectedly failed to lock to max DRAM pre-modeset!
[52932.606336] nvidia-modeset: ERROR: GPU:0: Failed to allocate 2743000 KBPS Iso and 4294967295 KBPS Dram
[52932.606344] nvidia-modeset: ERROR: GPU:0: Unexpectedly failed to lock to max DRAM pre-modeset!
It seems like it fails due to
I then tried changing the following line in extlinux.conf file to add 1980x1080@60, but to no avail
APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 video=DP-0:1980x1080@60 nvidia-drm.modeset=1
Any other suggestions on what’s going on here?
Please record the serial console log when you boot with ultra-wide monitor.
I’d need to get my hands on a TTL cable it looks like.
Is there a way to get access to the logs post-factum? I could try to load it once with the DP cable attached, then again without the cable attached, from where I could get access to the machine through the SSH. Are they stored somewhere?
Please test if you still observe this issue after you run sudo jetson_clocks command.
sorry, one more item here. Please switch the power mode to >= 15W by using nvpmodel command and see if you observe this issue.
The issue still persists after running sudo jetson_clocks and restarting.
Tried both mode 1 (25W) and mode 2 (MAXN_SUPER) and the issue still persists. No screen when DP cable is connected. With disconnected cable all modes work, I can ssh into the machine after boot and nvpmodel - q shows the correct mode.
Please test this
  1. Do not connect any monitor. Just boot up. Use ssh to enable 25W mode.
  2. enable jetson_clocks.
  3. Hotplug the monitor and share xorg log and dmesg.
Thank you Wayne, I booted up with no monitor connected, ran “sudo nvpmodel -m 1“ to switch to 25W mode (it was in MAXN_SUPER) then ran sudo jetson_clocks , then plugged the monitor.
Here’s the sequence and the contents of xorg
❯ ssh nano
Welcome to Ubuntu 22.04.5 LTS (GNU/Linux 5.15.148-tegra aarch64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/pro
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
Expanded Security Maintenance for Applications is not enabled.
0 updates can be applied immediately.
32 additional security updates can be applied with ESM Apps.
Learn more about enabling ESM Apps service at https://ubuntu.com/esm
Last login: Wed Dec 17 13:12:53 2025 from 192.168.50.231
mksergey@jetson-nano:~$ nvpmodel -q
NV Power Mode: MAXN_SUPER
2
mksergey@jetson-nano:~$ sudo nvpmodel -m 1
NV Power Mode: 25W
1
mksergey@jetson-nano:~$ sudo jetson_clocks
mksergey@jetson-nano:~$ cat /var/log/Xorg.0.log
[    20.813] (--) Log file renamed from "/var/log/Xorg.pid-1544.log" to "/var/log/Xorg.0.log"
[    20.821]
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
[    20.821] Current Operating System: Linux jetson-nano 5.15.148-tegra #1 SMP PREEMPT Thu Sep 18 15:08:33 PDT 2025 aarch64
[    20.821] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 video=DP-0:d bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[    20.821] xorg-server 2:21.1.4-2ubuntu1.7~22.04.16 (For technical support please see http://www.ubuntu.com/support)
[    20.821] Current version of pixman: 0.40.0
[    20.821] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    20.821] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    20.821] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 17 13:18:57 2025
[    20.848] (==) Using config file: "/etc/X11/xorg.conf"
[    20.848] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    20.848] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    20.865] (==) No Layout section.  Using the first Screen section.
[    20.865] (==) No screen section available. Using defaults.
[    20.865] (**) |-->Screen "Default Screen Section" (0)
[    20.865] (**) |   |-->Monitor "<default monitor>"
[    20.865] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    20.865] (**) |   |-->Device "Tegra0"
[    20.865] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    20.865] (==) Automatically adding devices
[    20.865] (==) Automatically enabling devices
[    20.865] (==) Automatically adding GPU devices
[    20.865] (==) Automatically binding GPU devices
[    20.865] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    20.895] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    20.895] 	Entry deleted from font path.
[    20.895] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    20.895] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    20.901] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    20.901] 	Entry deleted from font path.
[    20.901] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    20.901] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    20.901] (==) ModulePath set to "/usr/lib/xorg/modules"
[    20.901] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    20.901] (II) Loader magic: 0xaaaad1d14010
[    20.901] (II) Module ABI versions:
[    20.901] 	X.Org ANSI C Emulation: 0.4
[    20.901] 	X.Org Video Driver: 25.2
[    20.901] 	X.Org XInput driver : 24.4
[    20.901] 	X.Org Server Extension : 10.0
[    20.902] (++) using VT number 1
[    20.904] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[    20.904] (II) xfree86: Adding drm device (/dev/dri/card0)
[    20.904] (II) Platform probe for /sys/devices/platform/bus@0/13e00000.host1x/drm/drm/card0
[    20.905] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[    20.906] (II) no primary bus or device found
[    20.906] 	falling back to /sys/devices/platform/bus@0/13e00000.host1x/drm/drm/card0
[    20.906] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[    20.906] (II) "glx" will be loaded by default.
[    20.906] (II) LoadModule: "extmod"
[    20.906] (II) Module "extmod" already built-in
[    20.906] (II) LoadModule: "glx"
[    20.912] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    20.948] (II) Module glx: vendor="X.Org Foundation"
[    20.949] 	compiled for 1.21.1.4, module version = 1.0.0
[    20.949] 	ABI class: X.Org Server Extension, version 10.0
[    20.949] (II) LoadModule: "nvidia"
[    20.949] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    21.026] (II) Module nvidia: vendor="NVIDIA Corporation"
[    21.026] 	compiled for 1.6.99.901, module version = 1.0.0
[    21.026] 	Module class: X.Org Video Driver
[    21.026] (II) NVIDIA dlloader X Driver  540.4.0  Release Build  (bugfix_main)  (buildbrain@mobile-u64-6354-d6000)  Thu Sep 18 15:19:04 PDT 2025
[    21.026] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    21.027] (II) systemd-logind: releasing fd for 226:0
[    21.030] (II) Loading sub module "fb"
[    21.030] (II) LoadModule: "fb"
[    21.030] (II) Module "fb" already built-in
[    21.030] (II) Loading sub module "wfb"
[    21.030] (II) LoadModule: "wfb"
[    21.031] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    21.036] (II) Module wfb: vendor="X.Org Foundation"
[    21.036] 	compiled for 1.21.1.4, module version = 1.0.0
[    21.036] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    21.038] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    21.041] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    21.041] (==) NVIDIA(0): RGB weight 888
[    21.041] (==) NVIDIA(0): Default visual is TrueColor
[    21.041] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    21.041] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[    21.041] (**) NVIDIA(0): Enabling 2D acceleration
[    21.041] (II) Loading sub module "glxserver_nvidia"
[    21.041] (II) LoadModule: "glxserver_nvidia"
[    21.042] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[    21.491] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    21.492] 	compiled for 1.6.99.901, module version = 1.0.0
[    21.492] 	Module class: X.Org Server Extension
[    21.492] (II) NVIDIA GLX Module  540.4.0  Release Build  (bugfix_main)  (buildbrain@mobile-u64-6354-d6000)  Thu Sep 18 15:17:43 PDT 2025
[    21.493] (II) NVIDIA: The X server supports PRIME Render Offload.
[    21.887] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[    21.887] (--) NVIDIA(0):     DFP-0
[    21.887] (--) NVIDIA(0):     DFP-1
[    21.891] (II) NVIDIA(0): NVIDIA GPU Orin (nvgpu) (GA10B) at SoC (GPU-0)
[    21.891] (--) NVIDIA(0): Memory: 7802752 kBytes
[    21.891] (--) NVIDIA(0): VideoBIOS:
[    21.891] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    21.891] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[    21.891] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[    21.893] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    21.893] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    21.893] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    21.893] (==) NVIDIA(0):
[    21.893] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    21.893] (==) NVIDIA(0):     will be used as the requested mode.
[    21.893] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[    21.893] (--) NVIDIA(0):     AllowEmptyInitialConfiguration is enabled
[    21.910] (II) NVIDIA(0): Validated MetaModes:
[    21.910] (II) NVIDIA(0):     "NULL"
[    21.910] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    21.910] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[    21.910] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    21.910] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[    21.910] (II) NVIDIA:     access.
[    21.910] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[    21.914] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[    21.914] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    21.914] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    21.914] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    21.914] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    21.914] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    21.914] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    21.914] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    21.914] (II) NVIDIA(0):     Config Options in the README.
[    21.948] (II) NVIDIA(0): Setting mode "NULL"
[    21.962] (==) NVIDIA(0): Disabling shared memory pixmaps
[    21.962] (==) NVIDIA(0): Backing store enabled
[    21.962] (==) NVIDIA(0): Silken mouse enabled
[    21.962] (==) NVIDIA(0): DPMS enabled
[    21.963] (II) Loading sub module "dri2"
[    21.963] (II) LoadModule: "dri2"
[    21.963] (II) Module "dri2" already built-in
[    21.963] (II) NVIDIA(0): [DRI2] Setup complete
[    21.963] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    21.963] (II) Initializing extension Generic Event Extension
[    21.963] (II) Initializing extension SHAPE
[    21.963] (II) Initializing extension MIT-SHM
[    21.963] (II) Initializing extension XInputExtension
[    21.964] (II) Initializing extension XTEST
[    21.964] (II) Initializing extension BIG-REQUESTS
[    21.964] (II) Initializing extension SYNC
[    21.964] (II) Initializing extension XKEYBOARD
[    21.964] (II) Initializing extension XC-MISC
[    21.964] (II) Initializing extension SECURITY
[    21.964] (II) Initializing extension XFIXES
[    21.965] (II) Initializing extension RENDER
[    21.965] (II) Initializing extension RANDR
[    21.965] (II) Initializing extension COMPOSITE
[    21.965] (II) Initializing extension DAMAGE
[    21.965] (II) Initializing extension MIT-SCREEN-SAVER
[    21.965] (II) Initializing extension DOUBLE-BUFFER
[    21.965] (II) Initializing extension RECORD
[    21.966] (II) Initializing extension DPMS
[    21.966] (II) Initializing extension Present
[    21.966] (II) Initializing extension DRI3
[    21.966] (II) Initializing extension X-Resource
[    21.966] (II) Initializing extension XVideo
[    21.966] (II) Initializing extension XVideo-MotionCompensation
[    21.966] (II) Initializing extension SELinux
[    21.966] (II) SELinux: Disabled on system
[    21.966] (II) Initializing extension GLX
[    21.966] (II) Indirect GLX disabled.
[    21.967] (II) GLX: Another vendor is already registered for screen 0
[    21.967] (II) Initializing extension XFree86-VidModeExtension
[    21.967] (II) Initializing extension XFree86-DGA
[    21.967] (II) Initializing extension XFree86-DRI
[    21.967] (II) Initializing extension DRI2
[    21.967] (II) Initializing extension NV-GLX
[    21.967] (II) Initializing extension NV-CONTROL
[    22.143] (II) config/udev: Adding drm device (/dev/dri/card1)
[    22.144] (II) xfree86: Adding drm device (/dev/dri/card1)
[    22.144] (II) Platform probe for /sys/devices/platform/13800000.display/drm/card1
[    22.145] (EE) systemd-logind: failed to take device /dev/dri/card1: Device or resource busy
[    22.145] (II) LoadModule: "modesetting"
[    22.145] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    22.150] (II) Module modesetting: vendor="X.Org Foundation"
[    22.150] 	compiled for 1.21.1.4, module version = 1.21.1
[    22.150] 	Module class: X.Org Video Driver
[    22.150] 	ABI class: X.Org Video Driver, version 25.2
[    22.151] (II) modeset(G0): using drv /dev/dri/card1
[    22.155] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    22.155] (==) modeset(G0): RGB weight 888
[    22.155] (==) modeset(G0): Default visual is TrueColor
[    22.155] (II) Loading sub module "glamoregl"
[    22.155] (II) LoadModule: "glamoregl"
[    22.156] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    22.199] (II) Module glamoregl: vendor="X.Org Foundation"
[    22.199] 	compiled for 1.21.1.4, module version = 1.0.1
[    22.199] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    22.672] (II) modeset(G0): glamor X acceleration enabled on NVIDIA Tegra Orin (nvgpu)/integrated
[    22.672] (II) modeset(G0): glamor initialized
[    22.673] (II) modeset(G0): Output DP-1-1 has no monitor section
[    22.673] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    22.673] (==) modeset(G0): DPI set to (96, 96)
[    22.673] (II) Loading sub module "fb"
[    22.673] (II) LoadModule: "fb"
[    22.673] (II) Module "fb" already built-in
[    22.673] (EE) modeset(G0): drmSetMaster failed: Device or resource busy
[    22.675] (II) UnloadModule: "modesetting"
[    22.675] (II) UnloadSubModule: "glamoregl"
[    22.675] (II) Unloading glamoregl
[    22.675] xf86: found device 1
[    22.677] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=3 (/dev/input/event1)
[    22.677] (II) No input driver specified, ignoring this device.
[    22.677] (II) This device may have been added with another device file.
[    22.677] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=7 (/dev/input/event2)
[    22.678] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=8 (/dev/input/event3)
[    22.678] (II) No input driver specified, ignoring this device.
[    22.678] (II) This device may have been added with another device file.
[    22.679] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=9 (/dev/input/event4)
[    22.679] (II) No input driver specified, ignoring this device.
[    22.679] (II) This device may have been added with another device file.
[    22.680] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[    22.680] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[    22.680] (II) LoadModule: "libinput"
[    22.680] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    22.754] (II) Module libinput: vendor="X.Org Foundation"
[    22.754] 	compiled for 1.20.14, module version = 1.2.1
[    22.754] 	Module class: X.Org XInput Driver
[    22.754] 	ABI class: X.Org XInput driver, version 24.1
[    22.754] (II) Using input driver 'libinput' for 'gpio-keys'
[    22.756] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 46 paused 0
[    22.756] (**) gpio-keys: always reports core events
[    22.756] (**) Option "Device" "/dev/input/event0"
[    22.795] (II) event0  - gpio-keys: is tagged by udev as: Keyboard
[    22.795] (II) event0  - gpio-keys: device is a keyboard
[    22.796] (II) event0  - gpio-keys: device removed
[    22.796] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input0/event0"
[    22.796] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 6)
[    22.796] (**) Option "xkb_model" "pc105"
[    22.796] (**) Option "xkb_layout" "us"
[    22.797] (II) event0  - gpio-keys: is tagged by udev as: Keyboard
[    22.797] (II) event0  - gpio-keys: device is a keyboard
[    22.806] (II) config/udev: removing GPU device /sys/devices/platform/13800000.display/drm/card1 /dev/dri/card1
[    22.807] (II) config/udev: Adding drm device (/dev/dri/card1)
[    22.807] (II) xfree86: Adding drm device (/dev/dri/card1)
[    22.807] (II) Platform probe for /sys/devices/platform/13800000.display/drm/card1
[    22.808] (EE) systemd-logind: failed to take device /dev/dri/card1: Device or resource busy
[    22.808] (II) LoadModule: "modesetting"
[    22.808] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    22.808] (II) Module modesetting: vendor="X.Org Foundation"
[    22.808] 	compiled for 1.21.1.4, module version = 1.21.1
[    22.809] 	Module class: X.Org Video Driver
[    22.809] 	ABI class: X.Org Video Driver, version 25.2
[    22.809] (II) UnloadModule: "modesetting"
[    22.809] (II) Unloading modesetting
[    22.809] (II) Failed to load module "modesetting" (already loaded, 0)
[    22.809] (II) modeset(G0): using drv /dev/dri/card1
[    22.810] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    22.811] (==) modeset(G0): RGB weight 888
[    22.811] (==) modeset(G0): Default visual is TrueColor
[    22.811] (II) Loading sub module "glamoregl"
[    22.811] (II) LoadModule: "glamoregl"
[    22.811] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    22.818] (II) Module glamoregl: vendor="X.Org Foundation"
[    22.818] 	compiled for 1.21.1.4, module version = 1.0.1
[    22.818] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    22.822] (II) modeset(G0): glamor X acceleration enabled on NVIDIA Tegra Orin (nvgpu)/integrated
[    22.822] (II) modeset(G0): glamor initialized
[    22.822] (II) modeset(G0): Output DP-1-1 has no monitor section
[    22.822] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    22.822] (==) modeset(G0): DPI set to (96, 96)
[    22.822] (II) Loading sub module "fb"
[    22.822] (II) LoadModule: "fb"
[    22.822] (II) Module "fb" already built-in
[    22.822] (EE) modeset(G0): drmSetMaster failed: Device or resource busy
[    22.824] (II) UnloadModule: "modesetting"
[    22.824] (II) UnloadSubModule: "glamoregl"
[    22.824] (II) Unloading glamoregl
[    22.824] xf86: found device 1
[    24.175] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    24.176] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[    24.176] (--) NVIDIA(GPU-0): DFP-0: 2380.0 MHz maximum pixel clock
[    24.178] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    24.178] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    24.178] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[   295.850] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): connected
[   295.850] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): Internal DisplayPort
[   295.850] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): 2380.0 MHz maximum pixel clock
[   295.856] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): connected
[   295.856] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): Internal DisplayPort
[   295.856] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): 2380.0 MHz maximum pixel clock
[   295.862] (--) NVIDIA(GPU-0): DFP-1: disconnected
[   295.862] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[   295.862] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[   295.863] (--) NVIDIA(GPU-0):
[   295.891] (II) NVIDIA(0): Setting mode "DP-0: nvidia-auto-select @2560x1080 +0+0 {AllowGSYNC=Off, ViewPortIn=2560x1080, ViewPortOut=2560x1080+0+0}"
[   296.071] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): connected
[   296.071] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): Internal DisplayPort
[   296.071] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): 2380.0 MHz maximum pixel clock
[   296.077] (--) NVIDIA(GPU-0): DFP-1: disconnected
[   296.077] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[   296.077] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[   296.507] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): connected
[   296.507] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): Internal DisplayPort
[   296.507] (--) NVIDIA(GPU-0): DELL U4025QW (DFP-0): 2380.0 MHz maximum pixel clock
[   296.513] (--) NVIDIA(GPU-0): DFP-1: disconnected
[   296.513] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[   296.513] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
And here’s the output of dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6354-d6000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Sep 18 15:08:33 PDT 2025 ()
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x26d82f198 TPMFinalLog=0x25e3f0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x26d220000 MEMATTR=0x26718a018 ESRT=0x2671bba18 TPMEventLog=0x25e408018 RNG=0x25a920018 MEMRESERVE=0x25e40ac18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x00000002671bba18 to 0x00000002671bba50.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000024a000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x271307800-0x271309fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000277ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000025e22cfff]
[    0.000000]   node   0: [mem 0x000000025e22d000-0x000000025e3fffff]
[    0.000000]   node   0: [mem 0x000000025e400000-0x000000025e40afff]
[    0.000000]   node   0: [mem 0x000000025e40b000-0x000000025e40bfff]
[    0.000000]   node   0: [mem 0x000000025e40c000-0x000000026b8effff]
[    0.000000]   node   0: [mem 0x000000026b8f0000-0x000000026d82ffff]
[    0.000000]   node   0: [mem 0x000000026d830000-0x0000000271dfffff]
[    0.000000]   node   0: [mem 0x0000000271e00000-0x0000000271ffffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x000000027259ffff]
[    0.000000]   node   0: [mem 0x0000000272f00000-0x0000000272ffffff]
[    0.000000]   node   0: [mem 0x0000000276000000-0x0000000277ffffff]
[    0.000000] mminit::pageflags_layout_widths Section 0 Node 4 Zone 2 Lastcpupid 16 Kasantag 0 Flags 24
[    0.000000] mminit::pageflags_layout_shifts Section 21 Node 4 Zone 2 Lastcpupid 16 Kasantag 0
[    0.000000] mminit::pageflags_layout_pgshifts Section 0 Node 60 Zone 58 Lastcpupid 42 Kasantag 0
[    0.000000] mminit::pageflags_layout_nodezoneid Node/Zone ID: 64 -> 58
[    0.000000] mminit::pageflags_layout_usage location: 64 -> 42 layout 42 -> 24 unused 24 -> 0 page-flags
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] mminit::memmap_init Initialising map node 0 zone 0 pfns 524288 -> 1048576
[    0.000000] mminit::memmap_init Initialising map node 0 zone 2 pfns 1048576 -> 2588672
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] mminit::zonelist general 0:DMA = 0:DMA
[    0.000000] mminit::zonelist general 0:Normal = 0:Normal 0:DMA
[    0.000000] mminit::zonelist thisnode 0:DMA = 0:DMA
[    0.000000] mminit::zonelist thisnode 0:Normal = 0:Normal 0:DMA
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2001056
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 video=DP-0:d bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 7517440K/8133248K available (20160K kernel code, 4064K rwdata, 10056K rodata, 7680K init, 529K bss, 353664K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000363] Console: colour dummy device 80x25
[    0.000371] printk: console [tty0] enabled
[    0.000428] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000435] pid_max: default: 32768 minimum: 301
[    0.000471] LSM: Security Framework initializing
[    0.000495] Yama: becoming mindful.
[    0.000512] SELinux:  Initializing.
[    0.000591] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000607] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001683] rcu: Hierarchical SRCU implementation.
[    0.003764] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[    0.004068] Remapping and enabling EFI services.
[    0.004869] smp: Bringing up secondary CPUs ...
[    0.005348] Detected PIPT I-cache on CPU1
[    0.005387] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005407] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.005847] Detected PIPT I-cache on CPU2
[    0.005859] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.005874] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.006281] Detected PIPT I-cache on CPU3
[    0.006291] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.006305] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008753] Detected PIPT I-cache on CPU4
[    0.008780] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.008807] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009287] Detected PIPT I-cache on CPU5
[    0.009298] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.009313] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009370] smp: Brought up 1 node, 6 CPUs
[    0.009374] SMP: Total of 6 processors activated.
[    0.009377] CPU features: detected: 32-bit EL0 Support
[    0.009379] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.009381] CPU features: detected: Common not Private translations
[    0.009382] CPU features: detected: CRC32 instructions
[    0.009383] CPU features: detected: Data cache clean to Point of Persistence
[    0.009385] CPU features: detected: Generic authentication (architected algorithm)
[    0.009386] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009386] CPU features: detected: LSE atomic instructions
[    0.009387] CPU features: detected: Privileged Access Never
[    0.009389] CPU features: detected: RAS Extension Support
[    0.009391] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.050059] CPU: All CPU(s) started at EL2
[    0.053110] devtmpfs: initialized
[    0.072059] KASLR enabled
[    0.072265] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.072293] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.077324] pinctrl core: initialized pinctrl subsystem
[    0.078319] SMBIOS 3.6.0 present.
[    0.078332] DMI: NVIDIA NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super/Jetson, BIOS 36.4.7-gcid-42132812 09/18/2025
[    0.078902] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.080624] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.080755] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.080848] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.080906] audit: initializing netlink subsys (disabled)
[    0.081008] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[    0.082604] thermal_sys: Registered thermal governor 'step_wise'
[    0.082606] thermal_sys: Registered thermal governor 'user_space'
[    0.082607] thermal_sys: Registered thermal governor 'power_allocator'
[    0.086549] cpuidle: using governor menu
[    0.086752] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.086844] ASID allocator initialised with 32768 entries
[    0.088725] Serial: AMBA PL011 UART driver
[    0.099554] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.110861] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.120071] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.120076] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.120081] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.120084] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.121049] cryptd: max_cpu_qlen set to 1000
[    0.122698] ACPI: Interpreter disabled.
[    0.124038] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.124210] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.124489] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.124966] iommu: Default domain type: Translated
[    0.124973] iommu: DMA domain TLB invalidation policy: strict mode
[    0.125288] SCSI subsystem initialized
[    0.125372] libata version 3.00 loaded.
[    0.125481] vgaarb: loaded
[    0.125658] usbcore: registered new interface driver usbfs
[    0.125692] usbcore: registered new interface driver hub
[    0.125710] usbcore: registered new device driver usb
[    0.126155] pps_core: LinuxPPS API ver. 1 registered
[    0.126159] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.126172] PTP clock support registered
[    0.126255] EDAC MC: Ver: 3.0.0
[    0.127207] Registered efivars operations
[    0.127764] FPGA manager framework
[    0.127865] Advanced Linux Sound Architecture Driver Initialized.
[    0.128468] Bluetooth: Core ver 2.22
[    0.128504] NET: Registered PF_BLUETOOTH protocol family
[    0.128509] Bluetooth: HCI device and connection manager initialized
[    0.128520] Bluetooth: HCI socket layer initialized
[    0.128526] Bluetooth: L2CAP socket layer initialized
[    0.128538] Bluetooth: SCO socket layer initialized
[    0.128931] clocksource: Switched to clocksource arch_sys_counter
[    0.162880] VFS: Disk quotas dquot_6.6.0
[    0.162942] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.163171] pnp: PnP ACPI: disabled
[    0.166280] NET: Registered PF_INET protocol family
[    0.166568] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.168096] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.168194] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.168208] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.168297] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.169679] TCP: Hash tables configured (established 65536 bind 65536)
[    0.169836] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.169866] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.170045] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.170411] RPC: Registered named UNIX socket transport module.
[    0.170416] RPC: Registered udp transport module.
[    0.170418] RPC: Registered tcp transport module.
[    0.170419] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.170433] PCI: CLS 0 bytes, default 64
[    0.170725] Unpacking initramfs...
[    0.178016] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.178285] kvm [1]: IPA Size Limit: 48 bits
[    0.178322] kvm [1]: GICv3: no GICV resource entry
[    0.178330] kvm [1]: disabling GICv2 emulation
[    0.178353] kvm [1]: GIC system register CPU interface enabled
[    0.178421] kvm [1]: vgic interrupt IRQ9
[    0.178576] kvm [1]: VHE mode initialized successfully
[    0.181764] Initialise system trusted keyrings
[    0.181810] Key type blacklist registered
[    0.181910] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[    0.185568] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.186011] NFS: Registering the id_resolver key type
[    0.186041] Key type id_resolver registered
[    0.186045] Key type id_legacy registered
[    0.186101] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.186116] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.186142] ntfs: driver 2.1.32 [Flags: R/O].
[    0.186326] 9p: Installing v9fs 9p2000 file system support
[    0.186941] integrity: Platform Keyring initialized
[    0.199488] Key type asymmetric registered
[    0.199496] Asymmetric key parser 'x509' registered
[    0.199611] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.199622] io scheduler mq-deadline registered
[    0.199632] io scheduler kyber registered
[    0.210253] EINJ: ACPI disabled.
[    0.221927] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.223620] SuperH (H)SCI(F) driver initialized
[    0.223949] msm_serial: driver initialized
[    0.224616] printk: console [ttyTCU0] enabled
[    0.225605] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.225612] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.225621] arm-smmu 8000000.iommu: 	stage 1 translation
[    0.225622] arm-smmu 8000000.iommu: 	stage 2 translation
[    0.225624] arm-smmu 8000000.iommu: 	nested translation
[    0.225630] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    0.225632] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    0.225648] arm-smmu 8000000.iommu: 	Supported page sizes: 0x61311000
[    0.225649] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.225652] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.226690] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.226693] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.226696] arm-smmu 10000000.iommu: 	stage 1 translation
[    0.226697] arm-smmu 10000000.iommu: 	stage 2 translation
[    0.226698] arm-smmu 10000000.iommu: 	nested translation
[    0.226702] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    0.226704] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    0.226708] arm-smmu 10000000.iommu: 	Supported page sizes: 0x61311000
[    0.226709] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.226712] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.227117] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.227121] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.227122] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.227123] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.227124] arm-smmu 12000000.iommu: 	nested translation
[    0.227127] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    0.227131] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    0.227140] arm-smmu 12000000.iommu: 	Supported page sizes: 0x61311000
[    0.227143] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.227144] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.234447] loop: module loaded
[    0.235229] megasas: 07.717.02.00-rc1
[    0.239190] tun: Universal TUN/TAP device driver, 1.6
[    0.239750] thunder_xcv, ver 1.0
[    0.239778] thunder_bgx, ver 1.0
[    0.239796] nicpf, ver 1.0
[    0.240609] hclge is initializing
[    0.240642] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.240650] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.240687] e1000: Intel(R) PRO/1000 Network Driver
[    0.240693] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.240720] e1000e: Intel(R) PRO/1000 Network Driver
[    0.240724] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.240756] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.240761] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.240782] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.240788] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.241028] sky2: driver version 1.30
[    0.241682] VFIO - User Level meta-driver version: 0.3
[    0.243230] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.243239] ehci-pci: EHCI PCI platform driver
[    0.243265] ehci-platform: EHCI generic platform driver
[    0.243345] ehci-orion: EHCI orion driver
[    0.243411] ehci-exynos: EHCI Exynos driver
[    0.243463] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.243544] ohci-pci: OHCI PCI platform driver
[    0.243573] ohci-platform: OHCI generic platform driver
[    0.243653] ohci-exynos: OHCI Exynos driver
[    0.244083] usbcore: registered new interface driver usb-storage
[    0.245857] i2c_dev: i2c /dev entries driver
[    0.247112] pps pps0: new PPS source ktimer
[    0.247124] pps pps0: ktimer PPS source registered
[    0.247132] pps_ldisc: PPS line discipline registered
[    0.249168] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.251051] sdhci: Secure Digital Host Controller Interface driver
[    0.251056] sdhci: Copyright(c) Pierre Ossman
[    0.251522] Synopsys Designware Multimedia Card Interface Driver
[    0.252098] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.253244] ledtrig-cpu: registered to indicate activity on CPUs
[    0.254143] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.254703] tegra-bpmp bpmp: Adding to iommu group 0
[    0.256046] tegra-bpmp bpmp: firmware: e941463f35523d12ee54-da583751bbf
[    0.445146] Freeing initrd memory: 15488K
[    3.388204] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    3.388243] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    3.388246] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    3.388476] hid: raw HID events driver (C) Jiri Kosina
[    3.388819] usbcore: registered new interface driver usbhid
[    3.388825] usbhid: USB HID core driver
[    3.393558] optee: probing for conduit method.
[    3.393617] optee: revision 4.2 (d78bc5fa)
[    3.452800] optee: dynamic shared memory is enabled
[    3.453066] optee: initialized driver
[    3.455559] usbcore: registered new interface driver snd-usb-audio
[    3.457227] NET: Registered PF_PACKET protocol family
[    3.458331] Bluetooth: RFCOMM TTY layer initialized
[    3.458344] Bluetooth: RFCOMM socket layer initialized
[    3.458367] Bluetooth: RFCOMM ver 1.11
[    3.458628] 9pnet: Installing 9P2000 support
[    3.458743] Key type dns_resolver registered
[    3.459769] printk: console [tty0]: printing thread started
[    3.460466] printk: console [ttyTCU0]: printing thread started
[    3.460535] Loading compiled-in X.509 certificates
[    3.463283] Loaded X.509 cert 'Build time autogenerated kernel key: 9709b2c1b7afae80ccbf49cf4e8a5d004d951f84'
[    3.494111] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.496203] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    3.498355] serial-tegra 3100000.serial: RX in PIO mode
[    3.498364] serial-tegra 3100000.serial: TX in PIO mode
[    3.498483] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.499968] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    3.502564] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.502576] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.503173] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    3.508062] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    3.513479] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    3.519420] tegra-i2c c240000.i2c: Adding to iommu group 1
[    3.525147] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    3.525960] tegra-i2c c250000.i2c: Adding to iommu group 1
[    3.554356] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1767000 KHz, changing to: 1728000 KHz
[    3.558617] tegra-xusb 3610000.usb: Adding to iommu group 2
[    3.573652] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    3.573661] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.573677] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    3.574423] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    3.574447] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[    3.574567] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.574571] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    3.574575] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    3.575009] hub 1-0:1.0: USB hub found
[    3.575023] hub 1-0:1.0: 4 ports detected
[    3.575285] hub 2-0:1.0: USB hub found
[    3.575298] hub 2-0:1.0: 4 ports detected
[    3.576853] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[    3.577620] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[    3.577677] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    3.577740] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.617331] ALSA device list:
[    3.617337]   No soundcards found.
[    3.618719] sdhci-tegra 3400000.mmc: Got CD GPIO
[    3.663946] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    3.664672] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[    3.665614] Freeing unused kernel memory: 7680K
[    3.665685] Run /init as init process
[    3.665687]   with arguments:
[    3.665688]     /init
[    3.665688]   with environment:
[    3.665688]     HOME=/
[    3.665689]     TERM=linux
[    3.665690]     bl_prof_dataptr=2031616@0x271E10000
[    3.665691]     bl_prof_ro_ptr=65536@0x271E00000
[    3.678037] Checking overlayfs setting...
[    3.687630] Overlayfs is disabled...
[    3.693504] Root device found: mmcblk0p1
[    3.920925] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    4.037138] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[    4.037597] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[    4.045160]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    4.093605] hub 1-2:1.0: USB hub found
[    4.094780] hub 1-2:1.0: 4 ports detected
[    4.209854] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[    4.264180] hub 2-1:1.0: USB hub found
[    4.266399] hub 2-1:1.0: 4 ports detected
[    4.368934] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    7.652483] Found dev node: /dev/mmcblk0p1
[    7.890837] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    7.902660] Rootfs mounted over mmcblk0p1
[    7.942308] Switching from initrd to actual rootfs
[    8.319709] systemd[1]: System time before build time, advancing clock.
[    8.392670] NET: Registered PF_INET6 protocol family
[    8.394398] Segment Routing with IPv6
[    8.394406] In-situ OAM (IOAM) with IPv6
[    8.543321] systemd[1]: systemd 249.11-0ubuntu3.17 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.543684] systemd[1]: Detected architecture arm64.
[    8.556904] systemd[1]: Hostname set to <jetson-nano>.
[    8.574680] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    8.574697] systemd[1]: Set hardware watchdog to 2min.
[    9.092679] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[    9.129474] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.140073] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.248814] systemd[1]: Queued start job for default target Graphical Interface.
[    9.250779] systemd[1]: Created slice Slice /system/modprobe.
[    9.251504] systemd[1]: Created slice Slice /system/serial-getty.
[    9.252119] systemd[1]: Created slice Slice /system/systemd-fsck.
[    9.252559] systemd[1]: Created slice User and Session Slice.
[    9.252714] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.253113] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.254786] systemd[1]: Reached target Slice Units.
[    9.254856] systemd[1]: Reached target Mounting snaps.
[    9.254919] systemd[1]: Reached target Swaps.
[    9.254986] systemd[1]: Reached target Local Verity Protected Volumes.
[    9.255146] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    9.255381] systemd[1]: Listening on LVM2 poll daemon socket.
[    9.260432] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.260790] systemd[1]: Listening on Syslog Socket.
[    9.261035] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.261181] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.264072] systemd[1]: Listening on Journal Audit Socket.
[    9.264271] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.264505] systemd[1]: Listening on Journal Socket.
[    9.273339] systemd[1]: Listening on udev Control Socket.
[    9.285793] systemd[1]: Listening on udev Kernel Socket.
[    9.287020] systemd[1]: Mounting Huge Pages File System...
[    9.288331] systemd[1]: Mounting POSIX Message Queue File System...
[    9.289977] systemd[1]: Mounting Kernel Debug File System...
[    9.309986] systemd[1]: Mounting Kernel Trace File System...
[    9.312341] systemd[1]: Starting Journal Service...
[    9.312698] systemd[1]: Finished Availability of block devices.
[    9.317349] systemd[1]: Starting Set the console keyboard layout...
[    9.333208] systemd[1]: Starting Create List of Static Device Nodes...
[    9.334678] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    9.336144] systemd[1]: Starting Load Kernel Module configfs...
[    9.337587] systemd[1]: Starting Load Kernel Module drm...
[    9.361968] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.363645] systemd[1]: Starting Load Kernel Module fuse...
[    9.365622] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.380939] systemd[1]: Started Nameserver information manager.
[    9.381299] systemd[1]: Reached target Preparation for Network.
[    9.381594] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.414936] systemd[1]: Starting Load Kernel Modules...
[    9.416601] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.418049] systemd[1]: Starting Coldplug All udev Devices...
[    9.420344] systemd[1]: Started Journal Service.
[    9.425349] fuse: init (API version 7.34)
[    9.430386] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[    9.465639] systemd-journald[230]: Received client request to flush runtime journal.
[    9.490511] nvsciipc: loading out-of-tree module taints kernel.
[    9.491518] nvsciipc: loaded module
[    9.517582] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.518138] nvmap_page_pool_init: Total RAM pages: 1950688
[    9.518141] nvmap_page_pool_init: nvmap page pool size: 243836 pages (952 MB)
[    9.518200] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.549052] tegra-host1x 13e00000.host1x: Adding to iommu group 4
[    9.549829] host1x-context host1x-ctx.0: Adding to iommu group 5
[    9.549976] host1x-context host1x-ctx.1: Adding to iommu group 6
[    9.550104] host1x-context host1x-ctx.2: Adding to iommu group 7
[    9.550235] host1x-context host1x-ctx.3: Adding to iommu group 8
[    9.550362] host1x-context host1x-ctx.4: Adding to iommu group 9
[    9.550481] host1x-context host1x-ctx.5: Adding to iommu group 10
[    9.550591] host1x-context host1x-ctx.6: Adding to iommu group 11
[    9.550711] host1x-context host1x-ctx.7: Adding to iommu group 12
[    9.550821] host1x-context host1x-ctx.8: Adding to iommu group 13
[    9.550936] host1x-context host1x-ctx.9: Adding to iommu group 14
[    9.551133] host1x-context host1x-ctx.10: Adding to iommu group 15
[    9.551310] host1x-context host1x-ctx.11: Adding to iommu group 16
[    9.551452] host1x-context host1x-ctx.12: Adding to iommu group 17
[    9.551564] host1x-context host1x-ctx.13: Adding to iommu group 18
[    9.551684] host1x-context host1x-ctx.14: Adding to iommu group 19
[    9.551805] host1x-context host1x-ctx.15: Adding to iommu group 20
[    9.654144] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.887131] mc: Linux media interface: v0.10
[    9.907587] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: Adding to iommu group 21
[    9.908866] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.911374] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: Adding to iommu group 22
[    9.911877] videodev: Linux video capture interface: v2.00
[    9.919524] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.926416] scare-pigeon 13e00000.host1x:isp-thi@14b00000: Adding to iommu group 23
[    9.928026] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.970597] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 24
[   10.046660] tegra-vic 15340000.vic: Adding to iommu group 25
[   10.333894] tegra-nvdec 15480000.nvdec: Adding to iommu group 26
[   10.350515] Inserting ivc_ext.ko module
[   10.363975] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 27
[   10.392282] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 28
[   10.406587] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 29
[   10.408911] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[   10.414635] tegra-ofa 15a50000.ofa: Adding to iommu group 30
[   10.415556] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[   10.417229] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[   10.420009] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[   10.423221] drm drm: [drm] Cannot find any crtc or sizes
[   10.423376] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[   10.426683] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[   10.429158] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[   10.431916] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[   10.433789] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (219)
[   10.433793] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[   10.434401] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[   10.434796] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[   10.434800] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[   10.434802] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[   10.434805] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[   10.434807] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[   10.434809] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[   10.434889] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[   10.464943] [RCE] TCU debug prints will be routed to traces.
[   10.474831] tegra-dce d800000.dce: Adding to iommu group 31
[   10.475317] dce: dce_ipc_channel_init:311  Invalid Channel State [0x0] for ch_type [2]
[   10.475594] dce: tegra_dce_probe:245  Found display consumer device
[   10.475995] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.476002] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.476287] dce: dce_admin_send_cmd_ver:456  version : [0x3] err : [0x0]
[   10.476411] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[   10.476483] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[   10.476488] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[   10.476512] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [1] ...
[   10.476513] dce: dce_admin_setup_clients_ipc:561  Get queue info failed for [2]
[   10.476713] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[   10.476724] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [3] ...
[   10.477425] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[   10.477694] dce: dce_start_boot_flow:166  DCE_BOOT_DONE
[   10.524588] thermal-trip-event cpu-throttle-alert: cooling device registered.
[   10.525153] thermal-trip-event gpu-throttle-alert: cooling device registered.
[   10.525678] thermal-trip-event cv0-throttle-alert: cooling device registered.
[   10.529067] thermal-trip-event cv1-throttle-alert: cooling device registered.
[   10.543806] thermal-trip-event cv2-throttle-alert: cooling device registered.
[   10.544257] thermal-trip-event soc0-throttle-alert: cooling device registered.
[   10.545369] thermal-trip-event soc1-throttle-alert: cooling device registered.
[   10.547814] nv_platform 13800000.display: Adding to iommu group 32
[   10.553621] thermal-trip-event soc2-throttle-alert: cooling device registered.
[   10.562734] platform 13800000.display:nvdisplay-niso: Adding to iommu group 33
[   10.563455] thermal-trip-event hot-surface-alert: cooling device registered.
[   10.583801] driver not enabled, cannot register any devices
[   10.584246] tegra194-isp5 14800000.isp: Adding to iommu group 23
[   10.584756] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 21
[   10.586827] driver not enabled, cannot register any devices
[   10.587644] driver not enabled, cannot register any devices
[   10.587735] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 22
[   10.587815] (NULL device *): fops function table already registered
[   10.588904] driver not enabled, cannot register any devices
[   10.616798] spi-tegra114 3210000.spi: Adding to iommu group 1
[   10.663290] spi-tegra114 3230000.spi: Adding to iommu group 1
[   10.675766] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[   10.676194] at24 0-0057: 256 byte 24c02 EEPROM, read-only
[   10.703332] tegra-xudc 3550000.usb: Adding to iommu group 34
[   10.721014] tegra194-pcie 14100000.pcie: Adding to iommu group 35
[   10.725609] tegra-hda 3510000.hda: Adding to iommu group 36
[   10.732383] irq: IRQ234: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[   10.743788] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[   10.743811] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[   10.743820] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[   10.743825] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[   10.744136] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[   10.744141] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   10.818767] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[   10.818867] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[   10.823076] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[   10.831984] CAN device driver interface
[   10.840241] input: NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[   10.842389] tegra234-aon c000000.aon: Adding to iommu group 37
[   10.848942] tegra194-pcie 14100000.pcie: Link up
[   10.849526]  c000000.aon:hsp: probed
[   10.850472] tegra194-pcie 14100000.pcie: Link up
[   10.850705] tegra234-aon c000000.aon: init done
[   10.859529] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[   10.859574] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[   10.859578] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[   10.859581] pci_bus 0001:00: root bus resource [bus 00-ff]
[   10.859583] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[   10.859642] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[   10.859813] pci 0001:00:00.0: PME# supported from D0 D3hot
[   10.877004] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[   10.877185] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[   10.877387] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[   10.878491] pci 0001:01:00.0: supports D1 D2
[   10.878493] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[   10.885044] TT CAN feature is not supported
[   10.885169] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[   10.885222] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[   10.886207] 	 Message RAM Configuration
               	| base addr   |0x0c312000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
               	| mram size   |0x00001000|
[   10.887623] Release 3.2.3 from 09.06.2018
[   10.896576] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[   10.896589] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[   10.896595] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[   10.896702] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[   10.896735] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[   10.896739] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[   10.896745] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[   10.899624] pcieport 0001:00:00.0: Adding to iommu group 35
[   10.899790] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[   10.899971] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[   10.908229] tegra194-pcie 14160000.pcie: Adding to iommu group 38
[   10.913517] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[   10.913538] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[   10.913544] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[   10.913548] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[   10.913859] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[   10.913861] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   10.923908] irq: IRQ236: trimming hierarchy from :bus@0:pmc@c360000
[   10.924430] fusb301 1-0025: device id: 0x12
[   10.936012] net can0: mttcan device registered (regs=000000003e7da23f, irq=201)
[   10.954466] fusb301 1-0025: toggle_time(0) is not updated
[   10.954818] fusb301 1-0025: fusb301_set_mode: mode (32)(32)
[   10.955166] fusb301 1-0025: fusb301_detach: type[0x00] chipstate[0x01]
[   10.955172] fusb301 1-0025: fusb_update_state: 1
[   10.956001] fusb301 1-0025: mode[0x20], host_cur[0x02], dttime[0x00]
[   11.077543] usbcore: registered new interface driver btusb
[   11.110378] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.6fd4e69.20220818-105856
[   11.110388] rtk_btcoex: rtk_btcoex_init: version: 1.2
[   11.110390] rtk_btcoex: create workqueue
[   11.110522] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[   11.111901] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[   11.111905] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[   11.111907] rtk_btusb: patch_add
[   11.111909] rtk_btusb: auto suspend is disabled
[   11.111911] rtk_btusb: pid = 0x3549
[   11.111914] rtk_btusb: patch_add: Reset gEVersion to 0xff
[   11.111923] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[   11.121658] rtk_btusb: btusb_probe: done
[   11.121798] rtk_btusb: btusb_open start
[   11.121802] rtk_btusb: btusb_open hdev->promisc ==0
[   11.121803] rtk_btusb: download_patch start
[   11.121805] rtk_btusb: chip type value: 0x73
[   11.122793] usbcore: registered new interface driver rtk_btusb
[   11.123100] rtk_btusb: chip_type->status = 0x0, chip_type->chip = 0xbeef
[   11.123105] rtk_btusb: HCI reset.
[   11.134091] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[   11.134099] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[   11.134100] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   11.134101] rtk_btusb: load_firmware start
[   11.134102] rtk_btusb: lmp_version = 0x8822
[   11.134104] rtk_btusb: config filename rtl8822cu_config
[   11.137176] rtk_btusb: no bdaddr file /opt/bdaddr
[   11.137182] rtk_btusb: Origin cfg len 6
[   11.137184] rtk_btusb: 55 ab 23 87 00 00
[   11.137186] rtk_btusb: New cfg len 6
[   11.137187] rtk_btusb: 55 ab 23 87 00 00
[   11.137194] rtk_btusb: fw name is  rtl8822cu_fw
[   11.138667] rtk_btusb: This is not 8723a, use new patch style!
[   11.138671] rtk_btusb: rtk_get_eversion: gEVersion 255
[   11.140092] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[   11.140098] rtk_btusb: load_firmware: New gEVersion 3
[   11.140100] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[   11.140103] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[   11.140106] rtk_btusb: fw_version = 0x9a8cbc9
[   11.140108] rtk_btusb: number_of_total_patch = 3
[   11.140109] rtk_btusb: chipID 4
[   11.140110] rtk_btusb: patch_length 0x8590
[   11.140112] rtk_btusb: start_offset 0x00005d00
[   11.140113] rtk_btusb: Svn version: 1940234490
[   11.140115] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[   11.140117] rtk_btusb: buf_len = 0x8596
[   11.140129] rtk_btusb: fw: exists, config file: exists
[   11.140131] rtk_btusb: load_firmware done
[   11.140146] rtk_btusb: download_data start
[   11.162756] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   11.164172] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 1970-01-01T00:00:38 UTC (38)
[   11.248937] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[   11.282193] loop0: detected capacity change from 0 to 8
[   11.282276] loop1: detected capacity change from 0 to 357672
[   11.287050] loop2: detected capacity change from 0 to 141184
[   11.291272] loop3: detected capacity change from 0 to 126768
[   11.292820] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[   11.292823] unable to read xattr id index table
[   11.295394] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[   11.295399] unable to read xattr id index table
[   11.295696] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   11.296552] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   11.296754] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   11.302224] loop4: detected capacity change from 0 to 126768
[   11.305999] loop5: detected capacity change from 0 to 97448
[   11.314459] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[   11.314466] unable to read xattr id index table
[   11.318105] rtk_btusb: download_data done
[   11.318110] rtk_btusb: HCI reset.
[   11.320576] loop6: detected capacity change from 0 to 97448
[   11.329091] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[   11.329097] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[   11.329098] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   11.329105] rtk_btusb: Rtk patch end 0
[   11.329106] rtk_btusb: btusb_open set HCI UP RUNNING
[   11.329131] rtk_btcoex: Open BTCOEX
[   11.329134] rtk_btcoex: rtk_vendor_cmd_to_fw: opcode 0xfc1b
[   11.329143] rtk_btusb: btusb_open end
[   11.331089] rtk_btcoex: unknown hci command
[   11.333106] rtk_btcoex: BTCOEX hci_rev 0x09a8
[   11.333110] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[   11.353085] rtk_btusb: btusb_notify: hci0 evt 3
[   11.376654] loop7: detected capacity change from 0 to 1257552
[   11.408144] loop8: detected capacity change from 0 to 187776
[   11.411579] tegra210-admaif 290f000.admaif: Adding to iommu group 39
[   11.440251] loop9: detected capacity change from 0 to 357512
[   11.450548] loop10: detected capacity change from 0 to 90800
[   11.466363] rtl88x2ce 0001:01:00.0: Adding to iommu group 35
[   11.466537] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[   11.484209] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[   11.484214] unable to read xattr id index table
[   11.547194] rtl88x2ce 0001:01:00.0 wlP1p1s0: renamed from wlan0
[   12.020946] tegra194-pcie 14160000.pcie: Phy link never came up
[   13.022511] tegra194-pcie 14160000.pcie: Phy link never came up
[   13.022617] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[   13.022623] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[   13.022626] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[   13.022631] pci_bus 0004:00: root bus resource [bus 00-ff]
[   13.022633] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[   13.022691] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[   13.022874] pci 0004:00:00.0: PME# supported from D0 D3hot
[   13.028968] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[   13.029153] pcieport 0004:00:00.0: Adding to iommu group 38
[   13.029300] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[   13.029498] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[   13.029934] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[   13.030187] pci 0004:00:00.0: Removing from iommu group 38
[   13.030213] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[   13.032072] tegra194-pcie 141e0000.pcie: Adding to iommu group 40
[   13.033762] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[   13.033778] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[   13.033786] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[   13.033790] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[   13.034149] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[   13.034151] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   13.405161] rtk_btusb: btusb_flush add delay
[   13.415215] rtk_btusb: btusb_close
[   13.425629] rtk_btcoex: Close BTCOEX
[   13.425632] rtk_btcoex: -x
[   14.140929] tegra194-pcie 141e0000.pcie: Phy link never came up
[   14.646032] using random self ethernet address
[   14.646040] using random host ethernet address
[   14.808265] loop11: detected capacity change from 0 to 32768
[   14.841664] nv_nvsciipc_init.sh[675]: found /dev/nvsciipc
[   14.928868] nvsciipc: set_db start
[   14.928896] nvsciipc: set_db done
[   15.128982] tegra194-pcie 141e0000.pcie: Phy link never came up
[   15.129571] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[   15.129592] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[   15.129606] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[   15.129621] pci_bus 0007:00: root bus resource [bus 00-ff]
[   15.129627] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[   15.129748] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[   15.129977] pci 0007:00:00.0: PME# supported from D0 D3hot
[   15.149756] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[   15.150133] pcieport 0007:00:00.0: Adding to iommu group 40
[   15.150334] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[   15.153478] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[   15.155363] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[   15.160611] pci 0007:00:00.0: Removing from iommu group 40
[   15.160664] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[   15.178737] loop12: detected capacity change from 0 to 8
[   15.275980] tegra194-pcie 140a0000.pcie: Adding to iommu group 41
[   15.289445] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.289454] Bluetooth: BNEP filters: protocol multicast
[   15.289466] Bluetooth: BNEP socket layer initialized
[   15.321918] Mass Storage Function, version: 2009/09/11
[   15.321926] LUN: removable file: (no medium)
[   15.370240] NET: Registered PF_ALG protocol family
[   15.391500] using random self ethernet address
[   15.391508] using random host ethernet address
[   15.470731] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[   15.470777] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[   15.470790] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[   15.470797] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[   15.471386] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[   15.471389] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[   15.559027] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   15.577031] tegra194-pcie 140a0000.pcie: Link up
[   15.585305] rtk_btusb: btusb_open start
[   15.585348] rtk_btusb: btusb_open hdev->promisc ==0
[   15.585352] rtk_btusb: download_patch start
[   15.585361] rtk_btusb: chip type value: 0x73
[   15.587116] rtk_btusb: chip_type->status = 0x0, chip_type->chip = 0xbeef
[   15.587130] rtk_btusb: HCI reset.
[   15.591643] usb0: HOST MAC 36:a0:63:a4:7b:80
[   15.591667] usb0: MAC 36:a0:63:a4:7b:81
[   15.593312] usb1: HOST MAC 36:a0:63:a4:7b:82
[   15.593317] usb1: MAC 36:a0:63:a4:7b:83
[   15.598095] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[   15.598102] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[   15.598104] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   15.598105] rtk_btusb: Firmware already exists
[   15.598107] rtk_btusb: Rtk patch end 1
[   15.598110] rtk_btusb: btusb_open set HCI UP RUNNING
[   15.598142] rtk_btcoex: Open BTCOEX
[   15.598147] rtk_btcoex: rtk_vendor_cmd_to_fw: opcode 0xfc1b
[   15.598163] rtk_btusb: btusb_open end
[   15.599120] rtk_btcoex: unknown hci command
[   15.600219] tegra194-pcie 140a0000.pcie: Link up
[   15.600400] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[   15.600408] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[   15.600413] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[   15.600419] pci_bus 0008:00: root bus resource [bus 00-ff]
[   15.600421] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[   15.600476] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[   15.600502] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[   15.600638] pci 0008:00:00.0: PME# supported from D0 D3hot
[   15.601412] rtk_btcoex: BTCOEX hci_rev 0x09a8
[   15.601417] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[   15.606579] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[   15.607302] l4tbr0: port 1(usb0) entered blocking state
[   15.607326] l4tbr0: port 1(usb0) entered disabled state
[   15.607378] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[   15.607566] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[   15.607685] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[   15.607694] device usb0 entered promiscuous mode
[   15.610163] pci 0008:01:00.0: supports D1 D2
[   15.610170] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[   15.615517] l4tbr0: port 2(usb1) entered blocking state
[   15.615540] l4tbr0: port 2(usb1) entered disabled state
[   15.615752] device usb1 entered promiscuous mode
[   15.628428] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[   15.628440] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[   15.628446] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[   15.628542] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[   15.628634] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[   15.628663] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[   15.628666] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[   15.628671] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[   15.628904] pcieport 0008:00:00.0: Adding to iommu group 41
[   15.629373] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[   15.629761] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[   15.674634] loop11: detected capacity change from 0 to 32768
[   15.675436] r8168 0008:01:00.0: Adding to iommu group 41
[   15.675535] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[   15.675610] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   15.692571] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   15.694654] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   15.721669] r8168 0008:01:00.0 enP8p1s0: renamed from eth0
[   16.164523] enP8p1s0: 0xffff80000b141000, 48:b0:2d:eb:d9:3f, IRQ 270
[   17.497751] pstore: Using crash dump compression: deflate
[   17.497836] printk: console [ramoops-1]: printing thread started
[   17.497851] printk: console [ramoops-1] enabled
[   17.497853] pstore: Registered ramoops as persistent store backend
[   17.497854] ramoops: using 0x200000@0x2725f0000, ecc: 0
[   17.685751] nvgpu: 17000000.gpu                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   17.948766] zram: Added device: zram0
[   17.950915] zram: Added device: zram1
[   17.951204] zram: Added device: zram2
[   17.951448] zram: Added device: zram3
[   17.951639] zram: Added device: zram4
[   17.951869] zram: Added device: zram5
[   18.116653] zram0: detected capacity change from 0 to 1300464
[   18.222884] Adding 650228k swap on /dev/zram0.  Priority:5 extents:1 across:650228k SS
[   18.224293] zram1: detected capacity change from 0 to 1300464
[   18.230970] Adding 650228k swap on /dev/zram1.  Priority:5 extents:1 across:650228k SS
[   18.232156] zram2: detected capacity change from 0 to 1300464
[   18.238019] Adding 650228k swap on /dev/zram2.  Priority:5 extents:1 across:650228k SS
[   18.239178] zram3: detected capacity change from 0 to 1300464
[   18.245166] Adding 650228k swap on /dev/zram3.  Priority:5 extents:1 across:650228k SS
[   18.246380] zram4: detected capacity change from 0 to 1300464
[   18.252731] Adding 650228k swap on /dev/zram4.  Priority:5 extents:1 across:650228k SS
[   18.253930] zram5: detected capacity change from 0 to 1300464
[   18.259827] Adding 650228k swap on /dev/zram5.  Priority:5 extents:1 across:650228k SS
[   18.699769] overlayfs: idmapped layers are currently not supported
[   20.971122] ACK 04 d4
[   20.975758] ACK 04 d4
[   20.994628] IPv6: ADDRCONF(NETDEV_CHANGE): wlP1p1s0: link becomes ready
[   21.575732] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  540.4.0  Release Build  (buildbrain@mobile-u64-6354-d6000)  Thu Sep 18 15:33:51 PDT 2025
[   21.590454] [drm] [nvidia-drm] [GPU ID 0x00020000] Loading driver
[   21.870211] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   21.885763] [drm] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
[   21.887271] nv_platform 13800000.display: [drm] Cannot find any crtc or sizes
[   22.976707] audit: type=1326 audit(1766006340.056:2): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1660 comm="cupsd" exe="/snap/cups/1135/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffff8834ce0c code=0x50000
[   24.198894] audit: type=1326 audit(1766006341.280:3): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1660 comm="cupsd" exe="/snap/cups/1135/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffff8834ce0c code=0x50000
[   24.223121] audit: type=1326 audit(1766006341.304:4): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1733 comm="cups-browsed" exe="/snap/cups/1135/sbin/cups-browsed" sig=0 arch=c00000b7 syscall=274 compat=0 ip=0xffffbafb5b68 code=0x50000
[   25.863491] rfkill: input handler disabled
[   28.903546] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[  100.902411] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[  120.902344] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[  140.901303] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[  160.889424] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[  200.877000] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[  240.092167] nvgpu: 17000000.gpu                 fbp_pg_mask_store:1027 [INFO]  no value change, same mask already set
[  240.092190] nvgpu: 17000000.gpu                 tpc_pg_mask_store:1116 [INFO]  no value change, same mask already set
[  257.992464] nvgpu: 17000000.gpu             railgate_enable_store:365  [INFO]  railgate is disabled.
Is monitor working fine in this case? I saw no previous error log shown.
Yes, apologies, I should have clarified. The monitor works perfectly fine when it’s connected after the system boots. This has always worked.
The issue is only when I boot the system with the monitor cable plugged in. This way it “hangs“ and I don’t see it on my network to even try and ssh in.
Would these logs not be preserved if I tried to boot it with the monitor attached first (so failure), then disconnect the monitor, boot again (pass) and look at the logs?
