I need to send data on gpio in jetson Nx. by using ridgerun code and using a while loop to toggle sequentially the maximum frequency is 100KHz which I see in oscilloscope in a square wave. Is it true? does jetson kernel have a limitation on gpio?
or should I use fast gpio if Nx have?
what is the value of gpio-delay(in write mode) ?
the link :
https://developer.ridgerun.com/wiki/index.php/Gpio-int-test.c
Your topic was posted in the wrong category. I am moving this to the Jetson Xavier NX category for visibility.
hello user163861,
you may also refer to Topic 68606 to increase GPIO bit-bang speed. thanks
