Jetson NX Xavier Wifi module can't work?
My WIFI modules can’t work on Jetson NX Xavier. wifi module is RTL882CE which can work on windows.
Which JetPack SW you’re using?
Other deveoper said the RTL882CE can work well, see Wi-Fi compatibility issue with NVIDIA Jetson Xavier NX carrier board and the different Wi-Fi modules - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums.
