Jetson Orin AGX 64GB DevKit Fails to Flash NVMe with sdkmanager
Using sdkmanager I’m able to flash either of JP6 or JP5.1.2 on the EMMC.
However, in either case (I tried both JP6 and JP5.1.2) if I try to install to an NVME drive it fails near the end of installation since the device fails to completely boot (so the sdk times out waiting for it to boot).
Note that if I boot the jetson on the EMMC I’m able to see the NVME drive and format it, partition it etc. So it is definitely getting detected properly.
Here’s the minicom log of my last attempt
jetson.log (85.2 KB)
Can you please try this?
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/FlashingSupport.html#to-set-up-a-flash-drive-manually-for-booting
I’ve tried a few different variations of the command on that link without much success always encountering the same problem.
Here’s the latest attempt log, it always fails on not finding the /dev/mmcblk device, which I don’t know why it keeps trying to use that instead of the nvme device.
To be clear the way I’m doing this right now is with and x86 linux computer to which I directly connected the nvme, which is what I understood the instructions to be. If I misundertood the step here let me know.
/home/nvidia/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --external-only --direct nvme0n1 --usb-instance direct --device-instance 0 --flash-only --external-device nvme0n1p1 -c "./tools/kernel_flash/flash_l4t_external.xml" --direct nvme0n1 jetson-agx-orin-devkit nvme0n1p1
*  Step 1: Start the host connected device flashing process *
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
You didn’t tell me what command did you run.
I ran the command in the link you posted
$ sudo BOARDID=3701 BOARDSKU=0000 FAB=TS4 ./tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --external-device sda1 --direct nvme0n1 jetson-agx-orin-devkit external
And I tried a few different variation as well that seemed reasonable after the first one fail, but they all end up with the same error
$ sudo BOARDID=3701 BOARDSKU=0000 FAB=TS4 ./tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --external-device nvme0n1p1 --direct nvme0n1 jetson-agx-orin-devkit external
$ sudo BOARDID=3701 BOARDSKU=0000 FAB=TS4 ./tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --external-device nvme0n1p1 --direct nvme0n1 jetson-agx-orin-devkit nvme0n1p1
Can you please verify with a USB drive?
I ended up finding a solution for myself and getting JP6 installed for anyone reading this in the future.
I downloaded the BSP Driver Package and Sample Root File System from here: https://developer.nvidia.com/embedded/jetson-linux-r362
Followed the instructions here on step 2 to untar Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
From there I put my device in recovery mode and did: sudo ./flash.sh jetson-agx-orin-devkit nvme0n1p1
It is also unclear to me if having previously run “sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1” was useful or not to prep the emmc storage
In the end the final issue is that booting on the nvme drive still didn’t work, I had to go into the bios and override the boot order so it would still boot to emmc, but in one of the two commands above the emmc is flashed in a way to mount the nvme as its rootfs, so that booting to emmc still ends up using the nvme under the hood.
So I thought I was out of the weeds and while I did get it working for JP6 (which I think I had missed how important the --direct flashing i had done previously as suggested was to getting that working was)
However, JP6 doesn’t support USB2CAN, but USB2CAN works fine on JP5.1.2
So now I’m back with trying to install JP5.1.2 on my nvme, and just as before I’m getting stuck on needing “blockdev: cannot open /dev/mmcblk0boot0: No such file or directory”, which somehow that issue was fixed in JP6, but in JP5.1.2 the --direct script just will not work.
My understanding of /dev/mmcblk0boot0 is that either somehow the script expects to be run on the target device (aka jetson) or somehow the host is supposed to mount it in some way even though the jetson is in recovery mode?
How can I get that initrd flash script to figure out /dev/mmcblk0boot0? Is that device supposed to show up on the host?
How did you connect the NVMe drive to your host PC?
Direct through the M.2 socket?
Yes, directly in that host PC M2 socket
How about this?
