Hello, I am currently working on Flashing and Booting into a NVMe installed onto a Jetson AGX Orin Dev Kit 64gb. I run the following 2 scripts to flash the devices NVMe drive
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./flash.sh jetson-agx-orin-devkit nvme0n1p1
After running these scripts the flash process finishes successfully, however on boot I get the following errors in order
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1# [ 18.051543] ERROR: nvme0n1p1 not found
I am using VMware Workstation 16 pro to run Ubuntu 22.04.4 LTS x86_64 as the host system
I am also using Jetpack 6.0 with Jetson Linux 36.3 GA
I have previously booted into the eMMC and run the following command to verify the NVMe
lsblk -d -p | grep nvme | cut -d\ -f 1
I have also entered into the Boot Manager to verify It was attempting to boot into the NVMe instead of the eMMC
The NVMe being used is a WD_BLACK SN850X NVMe SSD 1TB
I am trying to make a script to automate a lot of things for a project, one of them is flashing and being able to boot off the NVMe. I have attempted to use the bellow commands, but it fails when it says “Waiting for target to boot…”. And on the display the AGX Orin is connected to all that is displaying is a flashing cursor light in the top left of the screen.
Thank you again!
I was able to find the answer. Turns out if you do not enable system wide USB passthrough on VMware it is unable to connect during the “Waiting for target to boot…” stage. Linked is the guide I followed, specifically the “Configuring System-wide USB Passthrough Settings” section.
