Hi all,
I’m using a Jetson Orin Nano (8GB, dev kit) and ran into an issue trying to get internet via my phone’s hotspot at a facility with no Wi‑Fi.
- Phone: [Android/iOS + model]
- Hotspot band: [2.4 GHz / 5 GHz / “Auto” if you’re not sure]
- Jetson OS: [JetPack version / Ubuntu version]
- Network manager: stock GUI (nm‑applet) / nmcli
Symptoms:
- The Jetson sees other Wi‑Fi networks normally when available.
- When I enable the phone hotspot, it either:
- doesn’t show up in the list, or
- shows up but fails to connect (“failed to activate connection” / password prompt loops).
Things I’ve tried:
- Toggling hotspot OFF/ON on the phone
Questions:
- Are there known issues with Jetson Wi‑Fi modules and phone hotspots (especially [your phone OS/band])?
- Is there a recommended way to force the Jetson to use 2.4 GHz only or specific security settings that work best with hotspots?
- Any logs/commands you recommend (e.g.,
nmcli,dmesg,journalctl) to diagnose this?
Thanks,
Mustafa
