IPhone does not connect to Jetson AGX Orin hotspot
Im having problems to connect an IPhone to the Orin Hotspot, although IPad, Android Phones, Laptops have no issues, IPhone refuses to connect to hotspot.
Hotspot has no internet connection (stand-alone).
nmcli connection edit β†’ print: shows following settings:
Connection profile details (Hotspot)
connection.id: Hotspot
connection.uuid: bb8d91bd-9169-45e9-b5b1-a94e7cc8c257
connection.stable-id: –
connection.type: 802-11-wireless
connection.interface-name: wlP1p1s0
connection.autoconnect: yes
connection.autoconnect-priority: 0
connection.autoconnect-retries: -1 (default)
connection.multi-connect: 0 (default)
connection.auth-retries: -1
connection.timestamp: 1758268059
connection.read-only: no
connection.permissions: –
connection.zone: –
connection.master: –
connection.slave-type: –
connection.autoconnect-slaves: -1 (default)
connection.secondaries: –
connection.gateway-ping-timeout: 0
connection.metered: unknown
connection.lldp: default
connection.mdns: -1 (default)
connection.llmnr: -1 (default)
connection.dns-over-tls: -1 (default)
connection.wait-device-timeout: -1
802-11-wireless.ssid: XXXXXXXXXX
802-11-wireless.mode: ap
802-11-wireless.band: bg
802-11-wireless.channel: 11
802-11-wireless.bssid: –
802-11-wireless.rate: 0
802-11-wireless.tx-power: 0
802-11-wireless.mac-address: –
802-11-wireless.cloned-mac-address: –
802-11-wireless.generate-mac-address-mask:–
802-11-wireless.mac-address-blacklist: –
802-11-wireless.mac-address-randomization:default
802-11-wireless.mtu: auto
802-11-wireless.seen-bssids: XXXXXXXXXXX
802-11-wireless.hidden: no
802-11-wireless.powersave: 0 (default)
802-11-wireless.wake-on-wlan: 0x1 (default)
802-11-wireless.ap-isolation: -1 (default)
802-11-wireless-security.key-mgmt: wpa-psk
802-11-wireless-security.wep-tx-keyidx: 0
802-11-wireless-security.auth-alg: –
802-11-wireless-security.proto: rsn
802-11-wireless-security.pairwise: ccmp
802-11-wireless-security.group: ccmp
802-11-wireless-security.pmf: 0 (default)
802-11-wireless-security.leap-username: –
802-11-wireless-security.wep-key0:
802-11-wireless-security.wep-key1:
802-11-wireless-security.wep-key2:
802-11-wireless-security.wep-key3:
802-11-wireless-security.wep-key-flags: 0 (none)
802-11-wireless-security.wep-key-type: unknown
802-11-wireless-security.psk:
802-11-wireless-security.psk-flags: 0 (none)
802-11-wireless-security.leap-password:
802-11-wireless-security.leap-password-flags:0 (none)
802-11-wireless-security.wps-method: 0x0 (default)
802-11-wireless-security.fils: 0 (default)
ipv4.method: shared
ipv4.dns: –
ipv4.dns-search: –
ipv4.dns-options: –
ipv4.dns-priority: 0
ipv4.addresses: –
ipv4.gateway: –
ipv4.routes: –
ipv4.route-metric: -1
ipv4.route-table: 0 (unspec)
ipv4.routing-rules: –
ipv4.ignore-auto-routes: no
ipv4.ignore-auto-dns: no
ipv4.dhcp-client-id: –
ipv4.dhcp-iaid: –
ipv4.dhcp-timeout: 0 (default)
ipv4.dhcp-send-hostname: yes
ipv4.dhcp-hostname: –
ipv4.dhcp-fqdn: –
ipv4.dhcp-hostname-flags: 0x0 (none)
ipv4.never-default: no
ipv4.may-fail: yes
ipv4.required-timeout: -1 (default)
ipv4.dad-timeout: -1 (default)
ipv4.dhcp-vendor-class-identifier: –
ipv4.dhcp-reject-servers: –
ipv6.method: auto
ipv6.dns: –
ipv6.dns-search: –
ipv6.dns-options: –
ipv6.dns-priority: 0
ipv6.addresses: –
ipv6.gateway: –
ipv6.routes: –
ipv6.route-metric: -1
ipv6.route-table: 0 (unspec)
ipv6.routing-rules: –
ipv6.ignore-auto-routes: no
ipv6.ignore-auto-dns: no
ipv6.never-default: no
ipv6.may-fail: yes
ipv6.required-timeout: -1 (default)
ipv6.ip6-privacy: -1 (unknown)
ipv6.addr-gen-mode: stable-privacy
ipv6.ra-timeout: 0 (default)
ipv6.dhcp-duid: –
ipv6.dhcp-iaid: –
ipv6.dhcp-timeout: 0 (default)
ipv6.dhcp-send-hostname: yes
ipv6.dhcp-hostname: –
ipv6.dhcp-hostname-flags: 0x0 (none)
ipv6.token: –
proxy.method: none
proxy.browser-only: no
proxy.pac-url: –
proxy.pac-script: –
Platform:
  • Distribution: Ubuntu 22.04 Jammy Jellyfish
  • Release: 5.15.148-tegra
WIfi card is:
0001:01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
Subsystem: Intel Corporation Dual Band Wireless-AC 8265
Flags: bus master, fast devsel, latency 0, IRQ 271, IOMMU group 5
Memory at 20a8000000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 8c-17-59-ff-ff-f3-b5-2e
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] L1 PM Substates
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Any help very welcome to convince the IPhone to connect to my Hotspot. If you need any further informnation please let me know.
Many thanks for any help.
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the Jetson category where it’s more appropriate
Cheers,
Tom
You may refer to TX2 Bluetooth connection problem with IOS (iphone) - Jetson & Embedded Systems / Jetson TX2 - NVIDIA Developer Forums to see if can help.
I dont see relevance to my problem. I need a wifi connection not a bluetooth connection.
Do you use AGX Orin developer kit with AzureWave RTL8822CE Wireless Network Adapter at M.2 Key E slot? And use Jetpack 6.2.1? Would like to confirm the hardware setup and software version you are using.
The HW is a Jetson AGX Orin 32GB H01 (Seeed Studio) with JetPck 6.2.1. The Wifi HW is Intel Corporation Wireless 8265 / 8275 (Rev 78). I guess all oth er info is given also at my initial post.
thx for any help.
Are the iPad and iPhone in same iOS version? Probably the issue is due to different iOS?
yes - both IPad and IPhone have IOS 18.7 installed. Any other suggestions ?
thx
Do you have other WIFI module for a try? Not sure but it seems like WPA3 may be a hard requirement for iPhone. And look like AC8265 does not support it per
Solved: Will WPA3 be certified on existing AC 8265 / 8260 / 7265 / 7260 NICs? - Intel Community
try this: nmcli con modify Hotspot 802-11-wireless-security.pmf disable
It’s related to a weird issue with wpa_supplicant and WPA3.
Hei,
sorry for late response, had other topics on my plate ;-)
…but, setting seems to fix the problem - now my IPhone connects to the wifi hotspot.
Many thanks for the help.
Hei again,
just to add some findiings regarding the settings, the mentioned settings works for IPhone but not for IPad. For IPad I had to set the settings to:
nmcli con modify Hotspot 802-11-wireless-security.pmf required
which hence allowed me to connect with IPhone and IPad.
klaus
