Jetson Orin Nano CAN
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/HR/ControllerAreaNetworkCan.html#controller-area-network-can
I did it, but CAN doesn’t work.
  • Orin nano
  • jetpack 6.0
I can’t check the following.
How do I check Kernel DTB?
By default, “+” nodes are enabled in the kernel device tree:
mttcan@c310000 {
status = “okay”;
mttcan@c320000 {
status = “okay”;
Hi simpwone,
Are you using the devkit or custom board for Orin Nano?
Are you using the internal mttcan and verifying with internal loopback test for CAN?
You can decompile the /boot/kernel_XXX.dtb to DTS to check its configurations.
