including CUDA runtime and CUDA SDK components
Via miniconda I reated an environment with Python 3.10. Afterwards I installded Tensorflow and Pytorch with NVIDIAS prebuilt installation wheels.
All installation processes went without error messages or warnings.
Nevertheless, the Jetson cannot be used properly neither with Tensorflow, nor with Pytorch.
First, Tensorflow behaviour. Tensorflow and Keras can be imported. But already during the import in the console there are warning (?) that “… cuda_executor.cc:984 could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
Your kernel may have built without NUMA support.”
This occurs several times.
The GPU seems to me recognized correctly “… device:GPU:0 with 2447MB memory : device:0, name: Orin, pci bus id: 0000:00:00.0, compute capability: 8.7”
Later there seems a more severe problem with "… can’t find libdevice directory ${CUDA_DIR}/nvvm/libdevice. … it seems, that the CUDA-related directory structure, as well as the required files have not been established during the initial installation process by the SDK manager.
under /usr/local one may find 3 “CUDA” directories: cuda, cuda-12, cuda-12.6. All of them consist of the subdirectories gds, include, lib64, targets but no “bin” subdirectory as suggested by the $PATH variable, composed by the SDK Manager
I guess, that the CUDA installation should have been done during the initial software installation via the SDK Manager.
During the installation process it was a little bit confusing for me, that the Jetson started to boot the Linux even the Linux image transfer to the Jetson was not finished yet (at about 70%) and the shortcut between pins 9 and 10 still has been there. Maybe this prevents the complete software installation ? Should I disconnect from the DevKit all other connections beside the USB-C cable to the control PC ?
I was running then under spyder some little programs using tensorflow and keras. The speed was about 3 - 4 times that of running on my old AMD Ryzen7 CPU.
Unfortunately Pytorch is still not possible to run
