Jetson Orin Nano (GPIO) -> with gpioset and gpioget
Got 2X jetson orin nano dev kit, connected via USB-C port and ssh’ing into the other one
Both running Jetpack 6.2 | ubuntu 22.04
uname -a
Linux ubuntu 5.15.148-tegra #1 SMP PREEMPT Tue Jan 7 17:14:38 PST 2025 aarch64 aarch64 aarch64 GNU/Linux
cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, DATE: Wed Jan  8 01:49:37 UTC 2025
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
How can i test/play around with the GPIO pins? And i missing any steps here?
Using gpioset i set PIN 4 to active-high on board “YYY” || sender
YYY@ubuntu:~$ gpioset --mode=time --sec=50 0 4=1
YYY@ubuntu:~$ gpioinfo | grep -i "PA.04"
	line   4:      "PA.04"    "gpioset"  output  active-high [used]
board “YYY” | | receiver, it shows 0 with gpioget
XXX@ubuntu:~$ gpioget gpiochip0 17
0
PIN 14 GND (Receiver) → PIN 6 (Sender)
PIN 7 GPIO09 (Sender) → PIN 11 UART_RTS
Using a female-to-female connectors to connect the PINS.
There is a known issue and please apply this patch to rebuild kernel:
Jetson/L4T/r36.4.x patches - eLinux.org
[GPIO] Fix bit 10(SFIO) been set by gpiod
isn’t this for Jetpack 6.1… would it work as well on jetpack 6.2?
[Jetpack 6.1/r36.4.0] Self-built kernel is overwritten after *sudo apt update && sudo apt upgrade*
https://elinux.org/Jetson/L4T/r36.4.x_patches
The patch is
Jetson AGX Orin FAQ
I can’t seem to warp my head around this…
usr/src/linux-headers-5.15.148-tegra-ubuntu22.04_aarch64/3rdparty/canonical/linux-jammy/kernel-source/drivers/pinctrl
drivers/pinctrl/tegra/pinctrl-tegra.c
how do i run locate the pinctrl-tegra.c file?
https://forums.developer.nvidia.com/t/40hdr-spi1-gpio-padctl-register-bit-10-effect-by-gpiod-tools-in-jp6/301171/19
You mean you don’t see pinctrl-tegra.c in your kernel source code? It should be at
kernel/kernel-jammy-src/drivers/pinctrl/tegra/pinctrl-tegra.c
hello
I see it now after downloading directly onto my jetson orin nano
Driver Package (BSP) Sources
Question - to use the patch workaround i need to reflash AGAIN after recompiling the kernel from a x86_64 bare-metal machine?
**cedjetson@ubuntu:~/Downloads/Linux_for_Tegra/source$ echo $CROSS_COMPILE **
**/home/cedjetson/l4t-gcc/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-**
**cedjetson@ubuntu:~/Downloads/Linux_for_Tegra/source$ makec -C kernel**
**bash: makec: command not found**
**cedjetson@ubuntu:~/Downloads/Linux_for_Tegra/source$ make -C kernel**
**make: Entering directory '/home/cedjetson/Downloads/Linux_for_Tegra/source/kernel'**
**Building kernel-jammy-src sources**
**make \**
**	ARCH=arm64 \**
**	-C /home/cedjetson/Downloads/Linux_for_Tegra/source/kernel/kernel-jammy-src  \**
**	LOCALVERSION=-rt-tegra \**
**	defconfig**
**make[1]: Entering directory '/home/cedjetson/Downloads/Linux_for_Tegra/source/kernel/kernel-jammy-src'**
***** Default configuration is based on 'defconfig'**
**/home/cedjetson/l4t-gcc/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-gcc: unknown compiler**
**scripts/Kconfig.include:44: Sorry, this compiler is not supported.**
**make[2]: *** [scripts/kconfig/Makefile:87: defconfig] Error 1**
**make[1]: *** [Makefile:630: defconfig] Error 2**
**make[1]: Leaving directory '/home/cedjetson/Downloads/Linux_for_Tegra/source/kernel/kernel-jammy-src'**
**make: *** [Makefile:30: kernel] Error 2**
**make: Leaving directory '/home/cedjetson/Downloads/Linux_for_Tegra/source/kernel'**
**cedjetson@ubuntu:~/Downloads/Linux_for_Tegra/source$**
Please follow the steps to rebuild kernel image:
No data from Joystick Logitech-f710 - #10 by DaneLLL
