Hello, I’m trying to rebuild the kernel of Jetson Orin Nano.
Purpose of this is to enable some kernel options.(Virtual Socket Protocol, etc.)
I’m a newbie of kernel compile.(studying about this)
I flashed Jetpack 6.0 with microSD.
I’m following this manual.
But I had trouble from 5th stage.
Described file path doesn’t match with mine.
So, after I finished ./nvbuild.sh -o $PWD/kernel_out successfully, I did followings.
# pwd: ~/Linux_for_Tegra/source/kernel_out/kernel/kernel-jammy-src/arch/arm64/boot/dts/nvidia
sudo cp -f * /boot/dtb/
sudo cp -f Image /boot/
then I rebooted. But nothing changed.
I found something related with vsock in the result directory(kernel_out) as you can see below.
How can I update these things(if it is correct) to original system?
