Jetson Orin Nano nvbuild.sh -o ***/kernel_out Directory "nvethernetrm" is not found, exiting
I am a new developer and recently needed to develop for the NVIDIA orin Nano development board.
development environment(PC):Ubuntu 18.04
Version in use: Jetson Linux 36.3
Follow this tutorial steps:Kernel Customization — Jetson Linux Developer Guide documentation (nvidia.com)
Use this command nvbuild.sh -o ***/kernel_out
Kernel Image: /home/zynq/NVIDIA/orin_Nano_prj/Linux_for_Tegra/source/kernel/output/kernel/kernel-jammy-src/arch/arm64/boot/Image
Kernel sources compiled successfully.
make: Leaving directory '/home/zynq/NVIDIA/orin_Nano_prj/Linux_for_Tegra/source/kernel/output/kernel'
Directory "nvethernetrm" is not found, exiting..
May I ask what causes it.Could you please tell me how to solve this problem.
thanks you all。
Thank you very much for your answer, according to your hint, I didn’t find files under this path/sources/kernel/nvethernetrm。I am on Jetson Linux | NVIDIA Developer to download。
Minimum version of host pc should be Ubuntu 20.04 for jetpack 6.0
As per this link
Please follow rel-36.3 document but not rel-35…if you are building rel-36 source…
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/Kernel/KernelCustomization.html?highlight=build%20kernel#building-the-jetson-linux-kernel
I changed the development environment to Ubuntu20.04 and still got the above error when compiling
Thank you very much, problem solved. The reason is that we still need to unpack kerner_oot_modules_src.tbz2, which contains nvethernetrm
