Jetson Orin Nano/NX DEV KIT- Issues with CUDA, Drivers, and External Storage
I’m currently working with a Jetson Orin Nano/NX Dev Kit 8GB and facing several issues.
When I try to use my GPU, commands like CUDA, Nvidia-SMI and tegrastats are not recognized. After checking, I noticed that NVIDIA JetPack is not installed. However, attempting to install it leads to broken package errors.
I came across several tutorials where people use SDK Manager on a separate host computer to flash the appropriate drivers and software onto the Jetson device. Is this the recommended approach, or is there another way to properly set up the system?
Additionally, I did not find an SD card slot on the board, leading me to believe that an external USB storage device is required for the setup. Can anyone confirm if this is the right solution?
Right now, I’m unable to initialize the necessary dependencies to run my code, and I don’t want to make things worse by using the wrong installation method.
I’d really appreciate any guidance on how to resolve these issues.
Thanks in advance for your help!
Best regards,
Raphaël Dias Coelho
Could you execute below command and share results for further check?
cat /etc/nv_tegra_release
cat cat /etc/nv_boot_control.conf
