Jetson Nano Orin (SDK manager doesn't install the packages)
Flashed my Jetson Orin Nano (dev kit) now it boots from NVME SSD.
But while using the SDK manager on a host Ubuntu-Machine the jetpack packages isn’t installed onto the Nano Device.
Installed Jetpack from the Nano directly
I’m trying to follow the lessons from https://github.com/dusty-nv/jetson-inference is there a way i can replicate the same files/packages like the micro-sd approach?
A lot of files seems to be missing and i’m not entirely sure how exactly to follow along.
Doing the easier micro-SD flash route previously, i do see that the jetson-inference (directory) was already pre-installed and other cuda packages as well at INITIAL bootup.
What do you mean with isn't installed here?
Have you run sudo apt install nvidia-jetpack?
