I was able to follow the tutorial to upgrade my Jetson Orin Nano, install with the SD card, and move docker to SSD. However, due to my development requirements, I would prefer that Jetpack Linux runs on the SSD as the root file system (this is because I intend to primarily use conda servers rather than dockers during development). Is it possible to use the tools in from SDK Manager to flash an image to an SSD without USB connection to the Orin Nano? I would love an img that I could just flash directly, since the SD card image doesn’t boot to install successfully on an SSD.
Kangalow
2
You can look at this and see if it meets your needs: https://youtu.be/497u-CcYvE8
To use the SDK Manager or CLI tools from the host requires a USB connection.
Related topics
| Newbie Steps to Regenerate Jetpack | 3 | 191 | December 15, 2025 | |
| Tech discussion. Why Jetson Orin Nano cannot support ssd image like SD card? | 2 | 194 | April 17, 2025 | |
| Jetson Orin Nano flash failing in SDK Manager docker container | 1 | 840 | December 25, 2023 | |
| Options to flash ssd on jetson Orin nano without Linux host computer | 1 | 353 | December 12, 2024 | |
| Writing SD Card image to SSD instead? | 6 | 2605 | April 14, 2023 | |
| Failing to Flash to Jetson Orin Nano Dev Kit using SDK Manager and Oracle VM | 9 | 1839 | July 20, 2023 | |
| Jetson orin Nano boot from NVMe SSD | 6 | 6091 | May 8, 2023 | |
| I can not flash the SSD of my Jetson Orin Nano | 3 | 791 | December 8, 2023 | |
| Jetson Orin Nano Developer Kit Flash - | 1 | 274 | March 21, 2025 | |
| Jetson Orin nano Setup experience | 1 | 367 | March 31, 2025 |
