[Jetson Orin Nano] system stuck when shutdown
Hi NV,
we hit a system stuck issue when did power on/off stress about 600 times on our carrier board,
SDK version is Jetson 35.3.1,
looks like related with GPU,
please help to clarify,
thanks.
ORIN_NANO_Jetson 35.3.1_shutdown_fail.log (620.2 KB)
[ 82.513160] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.513484] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] gnome-shell
[ 82.513792] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.514104] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] gnome-shell
[ 82.514512] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.514822] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] gnome-shell
[ 82.515187] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.515484] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] gnome-shell
[ 82.515760] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.517322] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] gnome-shell
[ 82.518562] nvgpu: 17000000.ga10b nvgpu_ioctl_tsg_dev_ioctl:850 [ERR] failed to host gk20a for ioctl cmd: 0x40045402
[ 82.528081] nvgpu: 17000000.ga10b gk20a_channel_release:459 [ERR] failed to release a channel!
[ 82.564727] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.565015] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.666207] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.666528] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.666810] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.667110] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.667352] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.667644] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.667871] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.668147] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.668533] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.670091] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.671312] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.677632] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.685490] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.696088] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.703911] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.714551] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 82.722369] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 82.733013] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
[ 85.083158] nvgpu: 17000000.ga10b gk20a_ctrl_ioctl_gpu_characteristics:370 [ERR] failed to power on gpu
[ 85.084956] nvgpu: 17000000.ga10b gk20a_ctrl_ioctl_gpu_characteristics:370 [ERR] failed to power on gpu
[ 85.666900] nvgpu: 17000000.ga10b gk20a_ctrl_ioctl_gpu_characteristics:370 [ERR] failed to power on gpu
[ 86.166593] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:678 [ERR] failed to host gk20a to submit gpfifo
[ 86.166602] nvgpu: 17000000.ga10b gk20a_ctrl_ioctl_gpu_characteristics:370 [ERR] failed to power on gpu
[ 86.166966] nvgpu: 17000000.ga10b nvgpu_submit_nondeterministic:680 [ERR] Xorg
That seems to be a known issue at R35.3.1 release, could you do the test with the latest JetPack5.1.2/L4TR35.4.1 again?
Hi Kay,
we will use latest SDK to test,
it any update will feedback to you,
thanks.
