Black screen and Re-entry into the system on Orin Nano
Black screen and Re-entry into the system on Orin Nano ,as log:
log.tar.zip (12.5 MB)
kerloc.log (110.3 KB)
Jetpack 5.1.1(r35.3.1).
使用过程中突然黑屏,所有应用自动关闭,请帮忙看一下什么原因,感谢。
log如下:
[ 1395.230334] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:92   [ERR]  Error reporting is not supported in this platform
[ 1395.243501] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(0), offset(0)
[ 1395.255928] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.267133] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1395.279764] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(0), offset(0)
[ 1395.292142] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.303362] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1395.315978] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(1), offset(2048)
[ 1395.328613] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.339817] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1395.352444] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(1), offset(2048)
[ 1395.352458] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.352479] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1395.388901] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(2), offset(4096)
[ 1395.388916] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.412776] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1395.425386] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(2), offset(4096)
[ 1395.438012] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.449218] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1395.461830] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(3), offset(6144)
[ 1395.474452] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.485654] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1395.498264] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(3), offset(6144)
[ 1395.510892] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[ 1395.522097] nvgpu: 17000000.ga10b gr_intr_handle_exception_interrupts:759  [ERR]  set gr exception notifier
[ 1395.532147] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 13 for ch 502
[ 1395.543037] __ga10b__ Channel Status - chip ga10b
[ 1395.543040] __ga10b__ ---------------------------
[ 1395.547889] __ga10b__ 502-ga10b, TSG: 9, pid 4363, refs: 5, deterministic: no, domain name: (default)
[ 1395.552730] __ga10b__ channel status:  in use on_pbdma, on_eng, pbdma_busy, eng_busy busy
[ 1395.562218] __ga10b__ RAMFC: TOP: 8000001ffda7b9d0 PUT: 001ffda7b9e4 GET: 001ffda7b9d0 FETCH: 000000000000 HEADER: 2140006c COUNT: 11110000 SEMAPHORE: addr 002000010000 payload 00000000000140da execute 00081003
[ 1395.570641] __ga10b__
[ 1395.589853] __ga10b__ 503-ga10b, TSG: 8, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1395.592381] __ga10b__ channel status:  in use idle not busy
[ 1395.601852] __ga10b__ RAMFC: TOP: 8000002004e88528 PUT: 002004e88528 GET: 002004e88528 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004e90000 payload 0000000000000000 execute 00100001
[ 1395.607587] __ga10b__
[ 1395.626819] __ga10b__ 504-ga10b, TSG: 7, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1395.626820] __ga10b__ channel status:  in use idle not busy
[ 1395.626826] __ga10b__ RAMFC: TOP: 8000002004bb0410 PUT: 002004bb0410 GET: 002004bb0410 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004ba0000 payload 0000000000000000 execute 00100001
[ 1395.626832] __ga10b__
[ 1395.663789] __ga10b__ 505-ga10b, TSG: 6, pid 4430, refs: 2, deterministic: no, domain name: (default)
[ 1395.663793] __ga10b__ channel status:  in use idle not busy
[ 1395.675807] __ga10b__ RAMFC: TOP: 80000020046d0118 PUT: 0020046d0118 GET: 0020046d0118 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 0020046c0000 payload 0000000000000000 execute 00100001
[ 1395.681548] __ga10b__
[ 1395.700767] __ga10b__ 506-ga10b, TSG: 5, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1395.703300] __ga10b__ channel status:  in use idle not busy
[ 1395.712773] __ga10b__ RAMFC: TOP: 8000002004319b58 PUT: 002004319b58 GET: 002004319b58 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004360000 payload 0000000000000000 execute 00100001
[ 1395.718512] __ga10b__
[ 1395.737729] __ga10b__ 507-ga10b, TSG: 4, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1395.740248] __ga10b__ channel status:  in use idle not busy
[ 1395.749721] __ga10b__ RAMFC: TOP: 8000002004300410 PUT: 002004300410 GET: 002004300410 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004030000 payload 0000000000000000 execute 00100001
[ 1395.755452] __ga10b__
[ 1395.774674] __ga10b__ 508-ga10b, TSG: 3, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1395.777188] __ga10b__ channel status:  in use idle not busy
[ 1395.786658] __ga10b__ RAMFC: TOP: 80000020040080a0 PUT: 0020040080a0 GET: 0020040080a0 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1395.792388] __ga10b__
[ 1395.811606] __ga10b__ 509-ga10b, TSG: 2, pid 2827, refs: 2, deterministic: no, domain name: (default)
[ 1395.814118] __ga10b__ channel status:  in use idle not busy
[ 1395.823590] __ga10b__ RAMFC: TOP: 8000002004009c20 PUT: 002004009c20 GET: 002004009c20 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1395.829319] __ga10b__
[ 1395.848540] __ga10b__ 510-ga10b, TSG: 1, pid 1974, refs: 2, deterministic: no, domain name: (default)
[ 1395.851067] __ga10b__ channel status:  in use idle not busy
[ 1395.860553] __ga10b__ RAMFC: TOP: 8000002004033c08 PUT: 002004033c08 GET: 002004033c08 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[ 1395.866281] __ga10b__
[ 1395.885510] __ga10b__ 511-ga10b, TSG: 0, pid 1974, refs: 2, deterministic: no, domain name: (default)
[ 1395.885511] __ga10b__ channel status:  in use idle not busy
[ 1395.885513] __ga10b__ RAMFC: TOP: 800000200404e8a8 PUT: 00200404e8a8 GET: 00200404e8a8 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[ 1395.885514] __ga10b__
[ 1395.885519] __ga10b__ PBDMA Status - chip ga10b
[ 1395.885525] __ga10b__ -------------------------
[ 1395.929641] __ga10b__ pbdma 0:
[ 1395.929645] __ga10b__   id: 9 - [tsg]     next_id: - -1 [channel] | status: valid
[ 1395.937454] __ga10b__   PBDMA_PUT 0000001ffda7c0e4 PBDMA_GET 0000001ffda7c090
[ 1395.945156] __ga10b__   GP_PUT    000000d6  GP_GET  000000d4  FETCH   000000d6 HEADER 20060034
[ 1395.952499] __ga10b__   HDR       2001c00d  SHADOW0 fda7b9e8  SHADOW1 0006fc1f
[ 1395.961351] __ga10b__ pbdma 1:
[ 1395.968781] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1395.971934] __ga10b__   PBDMA_PUT 0000000b7958b0e4 PBDMA_GET 0000000b7958b1e4
[ 1395.979911] __ga10b__   GP_PUT    00000000  GP_GET  7a954934  FETCH   00000000 HEADER e1956640
[ 1395.987257] __ga10b__   HDR       660f0c53  SHADOW0 7a013418  SHADOW1 f6485045
[ 1395.987260] __ga10b__ pbdma 2:
[ 1395.987261] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1395.987271] __ga10b__   PBDMA_PUT 000000f6d15ae214 PBDMA_GET 0000003cf4af1448
[ 1396.014659] __ga10b__   GP_PUT    00000000  GP_GET  7f0d5abc  FETCH   00000000 HEADER e1804f48
[ 1396.021996] __ga10b__   HDR       a0818010  SHADOW0 5a6404ea  SHADOW1 211668fb
[ 1396.030848] __ga10b__ pbdma 3:
[ 1396.038269] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.041420] __ga10b__   PBDMA_PUT 0000008f00000000 PBDMA_GET 000000a0e47d57f0
[ 1396.049379] __ga10b__   GP_PUT    00000000  GP_GET  0e4b93a0  FETCH   00000000 HEADER e04437c8
[ 1396.056721] __ga10b__   HDR       00000000  SHADOW0 bb719484  SHADOW1 155c0409
[ 1396.065572] __ga10b__ pbdma 4:
[ 1396.072994] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.076144] __ga10b__   PBDMA_PUT 0000000744040030 PBDMA_GET 0000008356238394
[ 1396.084103] __ga10b__   GP_PUT    00000000  GP_GET  23d384ee  FETCH   00000000 HEADER c1863824
[ 1396.091446] __ga10b__   HDR       62594210  SHADOW0 4644cbda  SHADOW1 43416929
[ 1396.100297] __ga10b__ pbdma 5:
[ 1396.107725] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.110878] __ga10b__   PBDMA_PUT 00000041a0c2434c PBDMA_GET 000000f49aa883b8
[ 1396.118841] __ga10b__   GP_PUT    00000000  GP_GET  d1d9d2b0  FETCH   00000000 HEADER 2007b908
[ 1396.126185] __ga10b__   HDR       a00183c1  SHADOW0 2c2b0572  SHADOW1 405c4508
[ 1396.135043] __ga10b__
[ 1396.142486] __ga10b__ ga10b eng 0:
[ 1396.142490] __ga10b__ id: 9 (tsg), next_id: -1 (channel), ctx status: valid
[ 1396.148609] __ga10b__ busy
[ 1396.155854] __ga10b__
[ 1396.158735] __ga10b__ ga10b eng 1:
[ 1396.161249] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1396.164842] __ga10b__
[ 1396.172720] __ga10b__ ga10b eng 2:
[ 1396.175250] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1396.178859] __ga10b__
[ 1396.186736] __ga10b__ ga10b eng 3:
[ 1396.186741] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1396.192854] __ga10b__
[ 1396.200737] __ga10b__ ga10b eng 4:
[ 1396.203261] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1396.206859] __ga10b__
[ 1396.214731] __ga10b__ ga10b eng 5:
[ 1396.217245] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1396.220838] __ga10b__
[ 1396.228714] __ga10b__
[ 1396.235513] mttcan c310000.mttcan can0: mttcan_poll_ir: some msgs lost on in Q0
[ 1396.260278] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1396.274537] nvgpu: 17000000.ga10b gv11b_mm_mmu_fault_handle_buf_valid_entry:525  [ERR]  page fault error: err_type = 0x8, fault_status = 0x200
[ 1396.287709] nvgpu: 17000000.ga10b      gv11b_fb_mmu_fault_info_dump:294  [ERR]  [MMU FAULT] mmu engine id:  64, ch id:  502, fault addr: 0x1fffe20000, fault addr aperture: 0, fault type: invalid pte, access type: virt read,
[ 1396.308192] nvgpu: 17000000.ga10b      gv11b_fb_mmu_fault_info_dump:307  [ERR]  [MMU FAULT] protected mode: 0, client type: gpc, client id:  t1_3, gpc id if client type is gpc: 0,
[ 1396.324735] nvgpu: 17000000.ga10b gv11b_mm_mmu_fault_handle_mmu_fault_refch:388  [ERR]  chid: 502 is referenceable but not bound to tsg
[ 1396.337260] nvgpu: 17000000.ga10b                nvgpu_rc_mmu_fault:352  [ERR]  mmu fault id=502 id_type=0 act_eng_bitmask=00000001
[ 1396.353883] __ga10b__ Channel Status - chip ga10b
[ 1396.353887] __ga10b__ ---------------------------
[ 1396.358752] __ga10b__ 502-ga10b, TSG: 4294967295, pid 4363, refs: 2, deterministic: no, domain name: (no tsg)
[ 1396.363621] __ga10b__ channel status: not in use idle not busy
[ 1396.373817] __ga10b__ RAMFC: TOP: 8000001ffda7c090 PUT: 001ffda7c0e4 GET: 001ffda7c090 FETCH: 000000000000 HEADER: 20060034 COUNT: 11110001 SEMAPHORE: addr 001ffda0c260 payload 000000000000004c execute 02000001
[ 1396.379810] __ga10b__
[ 1396.399041] __ga10b__ 503-ga10b, TSG: 8, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1396.399043] __ga10b__ channel status:  in use idle not busy
[ 1396.399045] __ga10b__ RAMFC: TOP: 8000002004e88528 PUT: 002004e88528 GET: 002004e88528 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004e90000 payload 0000000000000000 execute 00100001
[ 1396.399046] __ga10b__
[ 1396.399048] __ga10b__ 504-ga10b, TSG: 7, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1396.399050] __ga10b__ channel status:  in use idle not busy
[ 1396.399056] __ga10b__ RAMFC: TOP: 8000002004bb0410 PUT: 002004bb0410 GET: 002004bb0410 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004ba0000 payload 0000000000000000 execute 00100001
[ 1396.453694] __ga10b__
[ 1396.453696] __ga10b__ 505-ga10b, TSG: 6, pid 4430, refs: 2, deterministic: no, domain name: (default)
[ 1396.453698] __ga10b__ channel status:  in use idle not busy
[ 1396.453702] __ga10b__ RAMFC: TOP: 80000020046d0118 PUT: 0020046d0118 GET: 0020046d0118 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 0020046c0000 payload 0000000000000000 execute 00100001
[ 1396.490648] __ga10b__
[ 1396.509875] __ga10b__ 506-ga10b, TSG: 5, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1396.509876] __ga10b__ channel status:  in use idle not busy
[ 1396.509880] __ga10b__ RAMFC: TOP: 8000002004319b58 PUT: 002004319b58 GET: 002004319b58 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004360000 payload 0000000000000000 execute 00100001
[ 1396.527589] __ga10b__
[ 1396.546812] __ga10b__ 507-ga10b, TSG: 4, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1396.549331] __ga10b__ channel status:  in use idle not busy
[ 1396.558801] __ga10b__ RAMFC: TOP: 8000002004300410 PUT: 002004300410 GET: 002004300410 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004030000 payload 0000000000000000 execute 00100001
[ 1396.564531] __ga10b__
[ 1396.583751] __ga10b__ 508-ga10b, TSG: 3, pid 4363, refs: 2, deterministic: no, domain name: (default)
[ 1396.586265] __ga10b__ channel status:  in use idle not busy
[ 1396.595735] __ga10b__ RAMFC: TOP: 80000020040080a0 PUT: 0020040080a0 GET: 0020040080a0 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1396.601474] __ga10b__
[ 1396.620694] __ga10b__ 509-ga10b, TSG: 2, pid 2827, refs: 3, deterministic: no, domain name: (default)
[ 1396.623224] __ga10b__ channel status:  in use on_pbdma, on_eng, pbdma_busy, eng_busy busy
[ 1396.632697] __ga10b__ RAMFC: TOP: 8000002004009c20 PUT: 002004009c20 GET: 002004009c20 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[ 1396.641112] __ga10b__
[ 1396.660343] __ga10b__ 510-ga10b, TSG: 1, pid 1974, refs: 2, deterministic: no, domain name: (default)
[ 1396.660344] __ga10b__ channel status:  in use idle not busy
[ 1396.660347] __ga10b__ RAMFC: TOP: 8000002004033c08 PUT: 002004033c08 GET: 002004033c08 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[ 1396.660352] __ga10b__
[ 1396.697311] __ga10b__ 511-ga10b, TSG: 0, pid 1974, refs: 4, deterministic: no, domain name: (default)
[ 1396.699846] __ga10b__ channel status:  in use on_eng, pending, eng_busy busy
[ 1396.709337] __ga10b__ RAMFC: TOP: 8000001ffc16b3cc PUT: 001ffc16b62c GET: 001ffc16b3cc FETCH: 000000000000 HEADER: 2140006c COUNT: 11110000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[ 1396.716598] __ga10b__
[ 1396.735840] __ga10b__ PBDMA Status - chip ga10b
[ 1396.735841] __ga10b__ -------------------------
[ 1396.735845] __ga10b__ pbdma 0:
[ 1396.747706] __ga10b__   id: 2 - [tsg]     next_id: - -1 [channel] | status: valid
[ 1396.750872] __ga10b__   PBDMA_PUT 0000001fff7e4fd4 PBDMA_GET 0000001fff7e4ab4
[ 1396.758583] __ga10b__   GP_PUT    00000cd8  GP_GET  00000cd7  FETCH   00000cd8 HEADER 20000000
[ 1396.765934] __ga10b__   HDR       00000000  SHADOW0 ff7e4984  SHADOW1 0006501f
[ 1396.765937] __ga10b__ pbdma 1:
[ 1396.765939] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.765948] __ga10b__   PBDMA_PUT 0000000b7958b0e4 PBDMA_GET 0000000b7958b1e4
[ 1396.793378] __ga10b__   GP_PUT    00000000  GP_GET  7a954934  FETCH   00000000 HEADER e1956640
[ 1396.800723] __ga10b__   HDR       660f0c53  SHADOW0 7a013418  SHADOW1 f6485045
[ 1396.809575] __ga10b__ pbdma 2:
[ 1396.817005] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.820154] __ga10b__   PBDMA_PUT 000000f6d15ae214 PBDMA_GET 0000003cf4af1448
[ 1396.828118] __ga10b__   GP_PUT    00000000  GP_GET  7f0d5abc  FETCH   00000000 HEADER e1804f48
[ 1396.835462] __ga10b__   HDR       a0818010  SHADOW0 5a6404ea  SHADOW1 211668fb
[ 1396.844305] __ga10b__ pbdma 3:
[ 1396.851727] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.854878] __ga10b__   PBDMA_PUT 0000008f00000000 PBDMA_GET 000000a0e47d57f0
[ 1396.862834] __ga10b__   GP_PUT    00000000  GP_GET  0e4b93a0  FETCH   00000000 HEADER e04437c8
[ 1396.873474] __ga10b__   HDR       00000000  SHADOW0 bb719484  SHADOW1 155c0409
[ 1396.882436] mttcan c310000.mttcan can0: mttcan_poll_ir: some msgs lost on in Q0
[ 1396.899054] __ga10b__ pbdma 4:
[ 1396.899058] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.902198] __ga10b__   PBDMA_PUT 0000000744040030 PBDMA_GET 0000008356238394
[ 1396.910180] __ga10b__   GP_PUT    00000000  GP_GET  23d384ee  FETCH   00000000 HEADER c1863824
[ 1396.917543] __ga10b__   HDR       62594210  SHADOW0 4644cbda  SHADOW1 43416929
[ 1396.917546] __ga10b__ pbdma 5:
[ 1396.933855] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 1396.937012] __ga10b__   PBDMA_PUT 00000041a0c2434c PBDMA_GET 000000f49aa883b8
[ 1396.944994] __ga10b__   GP_PUT    00000000  GP_GET  d1d9d2b0  FETCH   00000000 HEADER 2007b908
[ 1396.952355] __ga10b__   HDR       a00183c1  SHADOW0 2c2b0572  SHADOW1 405c4508
[ 1396.961219] __ga10b__
[ 1396.968673] __ga10b__ ga10b eng 0:
[ 1396.971209] __ga10b__ id: 0 (tsg), next_id: 2 (tsg), ctx status: switch
[ 1396.974809] __ga10b__ busy
[ 1396.981709] __ga10b__
[ 1396.984596] __ga10b__ ga10b eng 1:
[ 1396.987119] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1396.990715] __ga10b__
[ 1396.990723] __ga10b__ ga10b eng 2:
[ 1396.990734] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1397.004708] __ga10b__
[ 1397.012592] __ga10b__ ga10b eng 3:
[ 1397.015121] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1397.018727] __ga10b__
[ 1397.026632] __ga10b__ ga10b eng 4:
[ 1397.026633] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1397.026634] __ga10b__
[ 1397.026637] __ga10b__ ga10b eng 5:
[ 1397.026638] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 1397.026639] __ga10b__
[ 1397.026641] __ga10b__
[ 1397.043220] nvgpu: 17000000.ga10b gv11b_fifo_locked_abort_runlist_active_tsgs:67   [ERR]  abort active tsgs of runlists set in runlists_mask: 0x00000001
[ 1397.075220] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 0 generated a mmu fault
[ 1397.085489] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 511
[ 1397.096648] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 1 generated a mmu fault
[ 1397.106937] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 510
[ 1397.118032] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 2 generated a mmu fault
[ 1397.128288] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 509
[ 1397.139371] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 3 generated a mmu fault
[ 1397.149694] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 508
[ 1397.160835] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 4 generated a mmu fault
[ 1397.170885] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 507
[ 1397.181653] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 5 generated a mmu fault
[ 1397.191703] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 506
[ 1397.202462] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 6 generated a mmu fault
[ 1397.212485] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 505
[ 1397.223237] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 7 generated a mmu fault
[ 1397.233262] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 504
[ 1397.244012] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 8 generated a mmu fault
[ 1397.254049] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 503
[ 1397.256114] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[ 1397.277434] nvgpu: 17000000.ga10b      ga10b_fifo_ctxsw_timeout_isr:277  [ERR]  Host pfifo ctxsw timeout error
[ 1425.856966] logitech-hidpp-device 0003:046D:4023.0003: HID++ 2.0 device connected.
Does the issue persist if you reboot the system? Looks like GPU malfunctions in the condition.
是的,重启后也会概率性的出现同样的问题。
Yes, the issue may also occur after restart。
Please try to reproduce it on Orin Nano developer kit. And share us the steps. So that we can replicate the issue and debug.
