Jetson Orin NX Hardware Schematics
Do you have any documentation that contains the Jetson Orin NX Schematics and its pins especifications?
We need to know the pins especifications and where they are located at the module. Is there any diagram that shows this information?
We don’t provide SOM schematic. Only carrier board schematic is provided.
We need to develop our carrier board to use in a especific context. For this reason, we need these pins specifications to build out the carrier board schematics. I mean by pins specifications only those which are the connectios of the module to the carrier board. Do you have any data sheet with this information?
If there isn’t any doc like that, the carrier board schematic provides this information?
You could refer to design guide document.
ok, thanks
FYI, in case it comes up, you won’t find any SPICE models, but if you ware doing RF impedance matching, you can likely get IBIS models.
