Hello, I’m using 8265NGW wifi module on nx board. But i can’t find wifi as you can see on picture. Is there something to set to connect wifi? Please tell me how do i connect wifi.
Not sure which JetPack SW you’re using, and it looks like the driver for Intel WiFi chips is not enabled in the default kernel config.
You can build it as a kernel module so you just copy the output .ko file to your device to make it work:
https://cateee.net/lkddb/web-lkddb/IWLWIFI.html
