Wi-fi module installation
I need to install a wifi module(EmWicon WMX7205-0 .11ax M.2 - 11479 - C-10-WMX7205-0 - 802.11ax M.2 - Techship), but I am facing this problem:
however the wifi chipset (WCN685x) is not supported until kernel version 5.17 hence kernel version does not have native support for the module.
module is detected with lspci command, but sudo nmcli device wifi connect password
output: no wifi module
OS: 5.10.104-tegra
board: Jetson Orin NX & Orin Nano Dual LAN Carrier Board - DSBOARD-ORNX-LAN | Forecr
module: Jetson Orin NX 8GB
wi-fi module driver support:
Linux:
QCA Standard LEA Linux Driver support kernel 4.9.11 & 5.4.0
Open Driver: ATH11K
Would be happy to receive useful information.
Welcome to the NVIDIA Developer forums.
I am moving your topic to the correct category for visibility.
The Wifi driver is not we can supported, you may contact with the manufactuer. Sorry for that.
