Orin NX JP6.2.2 WiFi module issue
Orin NX 8GB
Using the SDK of the JP5.x system, this WIFI module works properly.
Updated to JP6.x (including JP6.2.1/ JP6.2.2), still unable to be recognized using this WIFI module. However, using the official standard WIFI module works normally.
The WIFI module may need addition kernel configs. Please check this and give it a try:
Making sure you're not a bot!
[Jetpack 6.2] Intel AX200
Enable AX210 WIFI module
You may refer to this post for customizing kernel:
No data from Joystick Logitech-f710 - #10 by DaneLLL
