We made a driver for OV5647 and it works on external crystal.
We want to remove the crystal, using jetson clock.
Where is the clock out pin configuration?
Thanks for your help!
Please check the camera design guide.
In “Sensor Software Driver Programming Guide”
mclk
Name of the input clock for the device. The default value is extperiph1.
The maximum frequency for extperiph1 is 24 MHz. If a frequency greater than 24 MHz is required, use an external clock source.
If the value is extperiph1, Pin CAM0_MCLK output clock?
Yes, that’s correct.
