What is the maximum clock the pin supports i am connecting this to a sensor which needs a input clock 6to 36 MHZ how to configure this clock ?
The default value of CAM1_MCLK is 24Mhz, so it can be used by you directly.
Hi Trumany
can the CAM1_MCLK/CAM2_MCLK be set at 37.125MHz and 74.25 MHz? What is the range of MCLK?
Hi chinaQin
You can check which clock by cat /sys/kernel/debug/clock/vi_sensor/max (min) to know it.
Hi ShaneCCC,
Thank you for your reply.
the command line is: [code]
root@tegra-ubuntu:/sys/kernel/debug/clock/vi_sensor# cat /sys/kernel/debug/clock/vi_sensor/min
0
root@tegra-ubuntu:/sys/kernel/debug/clock/vi_sensor# cat /sys/kernel/debug/clock/vi_sensor/max
408000000
[code]
1 so it means i can set the MCLK at any value bettewn 0 and 408000000?
2 how can i set or change the MCLK value?
Hi chinaQin
You can define it in your DT like below.
ov5693_c@36 {
compatible = "nvidia,ov5693";
reg = <0x36>;
devnode = "video2";
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "ov5693";
avdd-reg = "vana";
iovdd-reg = "vif";
mode0 { // OV5693_MODE_2592X1944
mclk_khz = "24000";
num_lanes = "2";
