How to change clock configurations in the kernel device driver module at jetson TX1 R28.2?
for example,now i will change “TEGRA210_CLK_CLK_OUT_3” clock rate,How can to do it ?
hello sensor_test,
looks you would like to change the mclk rate of your customize sensor board, please configure this by the mclk_khz properties in the sensor device tree.
besides, you could also adding debug prints in the kernel driver to check whether these parse correctly or not.
for example,
diff --git a/drivers/media/platform/tegra/camera/sensor_common.c b/drivers/media/platform/tegra/camera/sensor_common.c
index 451edba..cef198a 100644
--- a/drivers/media/platform/tegra/camera/sensor_common.c
+++ b/drivers/media/platform/tegra/camera/sensor_common.c
@@ -81,6 +81,8 @@ static int sensor_common_parse_signal_props(
signal->mclk_freq = 0;
else
signal->mclk_freq = value;
pr_err("DEBUG: %s: mclk_khz= %d\n", __func__, signal->mclk_freq);
hello sensor_test,
may I have the status update, what’s your testing result.
thanks
Hello JerryChang,
I solved this question.
At the imx219.c file,it have a imx219_mclk_enable function.I can define IMX219_DEFAULT_CLK_FREQ value.
static void imx219_mclk_enable(struct camera_common_power_rail *pw)
clk_set_rate(pw->mclk, IMX219_DEFAULT_CLK_FREQ);
clk_prepare_enable(pw->mclk);
