Jetson Pin Connection Type
Hi! I am using Jetson Orin Nano signal pins and since I am using them in a vehicle with vibration, the cables that I connect to the pins with the jumper may become dislodged after a while.Can you help if you know of a way for me to make it more stable and less affected by vibration in order to prevent this?(I’m not thinking about soldering right now, I’m looking for a different connection solution because I don’t have a sensitive soldering tool)
Which pins are you talking about? The module-to-carrier board would be quite different than one of the 0.1" header pins.
