Jetson Power GUI
Orin NX
We created a power mode of 25W. with EMC max freq 3199000000 (EMC MAX FREQ 0)
upon power up we execute the command jetson_clocks --show.
the EMC current freq shows 665600000 , power GUI also shows 665600000. refer to first image.
then we execute jetson_clocks
the EMC current freq shows 3199000000, however power GUI shows 2133Mhz.
refer to second image
Can someone please explain the difference between jetson clocks and power GUI
@Vera Jiang can you redirect this to the appropriate forum? This is not Sanitizer-related. Thanks!
I see it already been redirected to “Jetson Nano”
Awesome thanks!
Hi zilkhanir1,
Are you using the devkit or custom board for Jetson Nano?
They should be the same.
The one showed in jetson clock is getten from bpmp node.
The one showed on Jetson Power GUI is read from emc path.
Could you also share your nvpmodel configuration in use for further check?
Using jetson nano devkit with jetson orin nx module
5.2.1
By the way i forgot to mention that some time the gui does show the correct frequency. But we dont know when.
Copyright (c) 2021-2022, NVIDIA CORPORATION. All rights reserved.
NVIDIA CORPORATION and its licensors retain all intellectual property
and proprietary rights in and to this software, related documentation
and any modifications thereto. Any use, reproduction, disclosure or
distribution of this software and related documentation without an express
license agreement from NVIDIA CORPORATION is strictly prohibited.
FORMAT:
< PARAM TYPE=PARAM_TYPE NAME=PARAM_NAME >
ARG1_NAME ARG1_PATH_VAL
ARG2_NAME ARG2_PATH_VAL
This starts a section of PARAM definitions, in which each line
has the syntax below:
ARG_NAME ARG_PATH_VAL
ARG_NAME is a macro name for argument value ARG_PATH_VAL.
PARAM_TYPE can be FILE, or CLOCK.
< POWER_MODEL ID=id_num NAME=mode_name >
PARAM1_NAME ARG11_NAME ARG11_VAL
PARAM1_NAME ARG12_NAME ARG12_VAL
PARAM2_NAME ARG21_NAME ARG21_VAL
This starts a section of POWER_MODEL configurations, followed by
lines with parameter settings as the format below:
PARAM_NAME ARG_NAME ARG_VAL
PARAM_NAME and ARG_NAME are defined in PARAM definition sections.
ARG_VAL is an integer for PARAM_TYPE of CLOCK, and -1 is taken
as INT_MAX. ARG_VAL is a string for PARAM_TYPE of FILE.
This file must contain at least one POWER_MODEL section.
< PM_CONFIG DEFAULT=default_mode >
This is a mandatory section to specify one of the defined power
model as the default.
PARAM DEFINITIONS
< PARAM TYPE=FILE NAME=CPU_ONLINE >
CORE_0 /sys/devices/system/cpu/cpu0/online
CORE_1 /sys/devices/system/cpu/cpu1/online
CORE_2 /sys/devices/system/cpu/cpu2/online
CORE_3 /sys/devices/system/cpu/cpu3/online
CORE_4 /sys/devices/system/cpu/cpu4/online
CORE_5 /sys/devices/system/cpu/cpu5/online
CORE_6 /sys/devices/system/cpu/cpu6/online
CORE_7 /sys/devices/system/cpu/cpu7/online
< PARAM TYPE=FILE NAME=FBP_POWER_GATING >
FBP_PG_MASK /sys/devices/gpu.0/fbp_pg_mask
< PARAM TYPE=FILE NAME=TPC_POWER_GATING >
TPC_PG_MASK /sys/devices/gpu.0/tpc_pg_mask
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_ENABLE >
GPU_PWR_CNTL_EN /sys/devices/gpu.0/power/control
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_DISABLE >
GPU_PWR_CNTL_DIS /sys/devices/gpu.0/power/control
< PARAM TYPE=CLOCK NAME=CPU_A78_0 >
FREQ_TABLE /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=CPU_A78_1 >
FREQ_TABLE /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=GPU >
FREQ_TABLE /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/available_frequencies
MAX_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/max_freq
MIN_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/min_freq
FREQ_TABLE_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/available_frequencies
MAX_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/max_freq
MIN_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/min_freq
MAX_FREQ /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
MAX_FREQ_KNEXT /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
< PARAM TYPE=CLOCK NAME=DLA0_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
< PARAM TYPE=CLOCK NAME=DLA0_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
< PARAM TYPE=CLOCK NAME=DLA1_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
< PARAM TYPE=CLOCK NAME=DLA1_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
< PARAM TYPE=CLOCK NAME=PVA0_VPS >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
< PARAM TYPE=CLOCK NAME=PVA0_AXI >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
POWER_MODEL DEFINITIONS
< POWER_MODEL ID=0 NAME=MODE_25_2_W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
FBP_POWER_GATING FBP_PG_MASK 2
TPC_POWER_GATING TPC_PG_MASK 240
GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
CPU_A78_0 MIN_FREQ 729600
CPU_A78_0 MAX_FREQ 1651200
GPU MIN_FREQ 0
GPU MAX_FREQ 918000000
GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ 614400000
DLA1_CORE MAX_FREQ 614400000
DLA0_FALCON MAX_FREQ 294400000
DLA1_FALCON MAX_FREQ 294400000
PVA0_VPS MAX_FREQ 704000000
PVA0_AXI MAX_FREQ -1
< PM_CONFIG DEFAULT=0 >
Are you using Orin Nano devkit board or Jetson Nano devkit board for Orin NX module..?
Is that a typo for Jetpack version?
We have only Jetpack 5.1.2 rather than 5.2.1.
May I know why you configure 0 for max EMC frequency?
Yes its a typo
This file was generated by Power estimator.
I think it is orin nano (i will replay with a certain answer later)
I’ve moved your topic to correct category for Orin Nano.
Okay, you could enable the settings for EMC.
What do you mean by you could enable the settings for EMC?
Sorry, it was my mis-understanding.
Please just use the following command to check current EMC frequency.
$ sudo cat /sys/kernel/debug/bpmp/debug/clk/emc/rate
