I have an issue when I execute jetson_clocks on a board with secureBoot+disk encryption enabled
root@obs0004:~# jetson_clocks --show
SOC family:tegra194 Machine:NVIDIA Jetson Xavier NX Developer Kit
Online CPUs: 0-3
cpu0: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu1: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu2: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu3: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu4: Online=0 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu5: Online=0 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
GPU MinFreq=803250000 MaxFreq=803250000 CurrentFreq=803250000
cat: /sys/kernel/debug/bpmp/debug/clk/emc/max_rate: No such file or directory
/usr/bin/jetson_clocks: line 384: [: : integer expression expected
cat: /sys/kernel/debug/bpmp/debug/clk/emc/min_rate: No such file or directory
cat: /sys/kernel/debug/bpmp/debug/clk/emc/rate: No such file or directory
cat: /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked: No such file or directory
EMC MinFreq= MaxFreq= CurrentFreq= FreqOverride=
Fan: PWM=0
NV Power Mode: MODE_10W_4CORE
Do you have idea how to fix that ?
This issue kill jtop service and I need it
Thank you so much.
hello JulienMoinard,
may I know which JetPack release you’re working with?
could you please list the node $ ll /sys/kernel/debug/bpmp/ for confirmation,
thanks
Hello JerryChang,
I use Jetpack4.5 and I don’t have the folder /sys/kernel/debug/bpmp/debug/ like you can see .
root@obs0004:~# ll /sys/kernel/debug/bpmp/
total 0
drwxr-xr-x 3 root root 0 janv. 1 1970 ./
drwx------ 100 root root 0 janv. 1 1970 ../
--w------- 1 root root 0 janv. 1 1970 clk_init
drwxr-xr-x 2 root root 0 janv. 1 1970 module/
-r--r--r-- 1 root root 0 janv. 1 1970 mount
-rw-r--r-- 1 root root 0 janv. 1 1970 mrq
-r--r--r-- 1 root root 0 janv. 1 1970 ping
-r--r--r-- 1 root root 0 janv. 1 1970 tag
-rw-r--r-- 1 root root 0 janv. 1 1970 trace
--w------- 1 root root 0 janv. 1 1970 trace_disable
-rw-r--r-- 1 root root 0 janv. 1 1970 trace_enable
-r--r--r-- 1 root root 0 janv. 1 1970 unmount
I can read on the forum for the TX2 with secureBoot bpmp debugfs will no more be available
if your board’s secure production fuse is blown, then bpmp debugfs will no more be available
can you check if [cat “/sys/kernel/debug/bpmp/mount”] from /etc/systemd/nv.sh has executed or not?
Do you remember, on empty board with the standard rootfs from Nvidia I have an issue with the first time Nvidia installer
Hello JerryChang,
It works ! thank you so much for your support ! my board is alive with encryption of boot and kernel.
My board start well with disk_enc_enable=0;
But for disk_enc_enable=1; the APP_ENC with 104857600 is not enougth
[ 0.0834 ] Signed and encrypted file: /data/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-xavier-nx-cti-NGX003.dtb_sigheader.encrypt.signed
l4t_sign_image.sh: Generate header for kernel_tegra1…
Maybe is related ? On fresh install I have an issue but if I restart the board I have a black screen without graphical interface but even if without graphical interface I can use my board in console mode but bpmp debugfs will no more be available and probably break the first time Nvidia installer too ?
Best regards,
Julien
the debug access is disabled when the SecurityMode is burned.
Thank you so you confirm me that I can’t use JTOP ?
Thank you.
it’s jetson_clocks --show to query all available frequencies, but it failed at EMC only.
so, please use nvpmodel to select power modes as an alternative approach.
thanks
Yes I confirm only EMC failed so I can find an alternative approach.
Thank you so much for your help.
Warm regards,
Julien.
