Dear NVIDIA Team,
We are designing a custom carrier board that supports dual 10GBASE-T, 1G, 100Mbps, and PCIe interfaces from the Jetson Thor T5000 module.
For 10G design implementation, there is a high-level reference in the Jetson Thor Series Modules Design Guide. However, no schematic reference is available in the design files for the 10G PHY (AQR113-B0-C) implementation. Kindly provide the schematic reference.
We are planning to implement dual 10G Ethernet using the HS_UPHY1_L4 and HS_UPHY1_L5 lines with two 10G PHYs. Please confirm whether this configuration is supported on the Jetson Thor T5000 module, both at the hardware level and with the required software support.
Regarding 1G and 100Mbps Ethernet, I would like to understand how these interfaces can be implemented on the carrier board.
I see a reference in the design guidelines document using a PCIe controller (Ethernet over PCIe). However, the PHY used in the reference design is not available for procurement. I would like to know whether you can suggest an alternative PCIe-to-Ethernet PHY/controller and whether it is possible to use one PCIe controller for 1G Ethernet and the other for 100Mbps Ethernet.
Alternatively, please let us know whether the AQR113-B0-C 10G PHY can be connected to MGBE Controllers 2 and 3 and configured to support 1G and 100Mbps Ethernet.
Please confirm whether these configurations are supported by the hardware and default software, without requiring any additional software customization from our side, except for the pinmux configuration.
Regarding PCIe, we plan to connect a PCIe Gen4 x8 device to C4 and a PCIe Gen5 x2 device through an M.2 connector to C3.
Kindly confirm whether the above configurations are supported and provide the reference design files for the 10G PHY implementation at the earliest.
Regards,
Anoop
