10 GbE - PHY
Hi Nvidia Team
Is there any recommendation for a 10 Gbit PHY to use with the XFI Interface? Will NVidia support the integration of a specific device? Would you recommend to use the AQR113 as for the AGX Orin? Thank you for your support.
Kind regards
Please refer to the Jetson T5000 data sheet, Jetson T5000 Series Modules Data Sheet https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/thor/docs/Jetson_T5000_Modules_DS_DS11945001_v1.1.pdf
Hi sgursal
Thank you for the hint, but there are no specific PHYs listed that are supported. Do you have recommendations or can we use any 10 Gbit PHY with the XFI interface?
AQR113C-B1-I seems a good option.
Hi sgursal
Ok thank you. Which XFI interfaces should be used first? XFI0 and XFI1 are ok or should we consider others?
Please refer to the Thor Design Guide, Jetson Thor Series Modules Interface Design Guide https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/thor/docs/jetson_thor_series_modules_designguide.pdf
You could choose any of the supported MGBE controllers as in above Table 7-4.
For updates, please refer to How to design four MGBE used AQR113C - #12 by sgursal
