Jetson thor 的timer中断怎么配置?
Jetson thor 的timer只有4个中断吗?GIC_SPI 773是TIM0中断?
tegra264.dtsi中的timer节点的interrupts属性配置了4个中断号,GIC_SPI 773 对应timer0的中断么?776是timer3中断?
	timer@8000000 {
		compatible = "nvidia,tegra234-timer";
		reg = <0x0 0x08000000 0x0 0x00140000>;
		interrupts = <GIC_SPI 773 IRQ_TYPE_LEVEL_HIGH>,
			     <GIC_SPI 774 IRQ_TYPE_LEVEL_HIGH>,
			     <GIC_SPI 775 IRQ_TYPE_LEVEL_HIGH>,
			     <GIC_SPI 776 IRQ_TYPE_LEVEL_HIGH>;
		status = "disabled";
Sorry for the late response.
我仍然需要帮助,但我没有得到有用的答案。根据TRM,Thor拥有16个 Nv timer,我希望能够使用某个Nv timer,并注册中断,但是内核设备树节点compatible = "nvidia,tegra234-timer";看起来只是一个看门狗驱动?我希望英伟达能提供通用的定时器中断程序
~1217
Hi BossOfNvidia,
Are you using the devkit or custom board for Thor?
The node timer@8000000 seems not enabled in your case.
May I know what’s your use case for this?
Do you have custom driver to register the interrupt through request_irq()?
