Hello linuxdev, I don’t know how to say thanks for you trying to help me with so much details.
Bus 003 and Bus 004 are the bold lines in my last post.
The following are the red lines from “journalctl -b0” (the log file has almost 6000 lines, seems I cannot attach a file here, I suspect the bold lines may cause problems):
Jul 15 15:17:12 wt70707xps systemd-udevd[319]: invalid key/value pair in file /etc/udev/rules.d/dji-usb.rules on line 3, starting at character 1 (‘$’)
Jul 15 15:17:12 wt70707xps systemd-udevd[319]: invalid key/value pair in file /etc/udev/rules.d/dji-usb.rules on line 5, starting at character 1 (‘r’)
Jul 15 15:17:12 wt70707xps systemd-udevd[397]: Error running install command for pinctrl_intel
Jul 15 15:17:12 wt70707xps systemd-udevd[389]: Error running install command for pinctrl_intel
Jul 15 15:17:13 wt70707xps smartd[1008]: Problem creating device name scan list
Jul 15 15:17:13 wt70707xps smartd[1008]: In the system’s table of devices NO devices found to scan
Jul 15 15:17:13 wt70707xps NetworkManager[931]: nm_device_get_device_type: assertion ‘NM_IS_DEVICE (self)’ failed
Jul 15 15:17:13 wt70707xps bluetoothd[955]: Failed to obtain handles for “Service Changed” characteristic
Jul 15 15:17:13 wt70707xps bluetoothd[955]: Not enough free handles to register service
Jul 15 15:17:13 wt70707xps bluetoothd[955]: Error adding Link Loss service
Jul 15 15:17:13 wt70707xps bluetoothd[955]: Current Time Service could not be registered
Jul 15 15:17:13 wt70707xps bluetoothd[955]: gatt-time-server: Input/output error (5)
Jul 15 15:17:13 wt70707xps bluetoothd[955]: Sap driver initialization failed.
Jul 15 15:17:13 wt70707xps bluetoothd[955]: sap-server: Operation not permitted (1)
Jul 15 15:17:13 wt70707xps bluetoothd[955]: Failed to set mode: Blocked through rfkill (0x12)
Jul 15 15:17:14 wt70707xps lightdm[1452]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or direct
Jul 15 15:17:14 wt70707xps lightdm[1452]: PAM adding faulty module: pam_kwallet.so
Jul 15 15:17:14 wt70707xps lightdm[1452]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or dire
Jul 15 15:17:14 wt70707xps lightdm[1452]: PAM adding faulty module: pam_kwallet5.so
Jul 15 15:17:14 wt70707xps lightdm[1531]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or direct
Jul 15 15:17:14 wt70707xps lightdm[1531]: PAM adding faulty module: pam_kwallet.so
Jul 15 15:17:14 wt70707xps lightdm[1531]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or dire
Jul 15 15:17:14 wt70707xps lightdm[1531]: PAM adding faulty module: pam_kwallet5.so
Jul 15 15:17:15 wt70707xps systemd[1]: Failed to start User Manager for UID 0.
Jul 15 15:17:15 wt70707xps su[1664]: pam_systemd(su:session): Failed to create session: Start job for unit user@0.service failed with ‘failed’
Jul 15 15:17:15 wt70707xps pulseaudio[1619]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.Serv
Jul 15 15:17:17 wt70707xps kernel: ath10k_pci 0000:3a:00.0: could not fetch firmware file ‘ath10k/QCA6174/hw3.0/firmware-5.bin’: -2
Jul 15 15:17:22 wt70707xps wpa_supplicant[2040]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
Jul 15 15:17:22 wt70707xps wpa_supplicant[2040]: dbus: Failed to construct signal
Jul 15 15:17:22 wt70707xps wpa_supplicant[2040]: Could not read interface p2p-dev-wlp58s0 flags: No such device
Jul 15 15:17:42 wt70707xps bluetoothd[955]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Jul 15 15:17:42 wt70707xps pulseaudio[2591]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.Serv
Jul 15 15:18:14 wt70707xps kernel: CPU3: Core temperature above threshold, cpu clock throttled (total events = 1)
Jul 15 15:18:14 wt70707xps kernel: CPU1: Core temperature above threshold, cpu clock throttled (total events = 1)
Jul 15 15:18:14 wt70707xps kernel: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
Jul 15 15:18:14 wt70707xps kernel: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
Jul 15 15:18:14 wt70707xps kernel: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
Jul 15 15:18:14 wt70707xps kernel: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
journalctl.txt (729 KB)
