Hi
We have a custom carrier board with a TX2. Instead of a HDMI Display, our board uses a Display Port as primary interface. With JetPack 3.3, we were able to make the DP running. Now we tried the same with the JetPack Version 4.2 and so far, the system won’t boot up and display is not working. As mentioned in other threads, it is possible that the system does not boot completely, because no display is recognized. In JetPack 3.3 was already a DTB File for Display Port, in 4.2 this is missing. The boot log shows the following:
[0001.565] E> I2C: slave not found in slaves.
[0001.570] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.577] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.583] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.593] E> eeprom: Retry to read I2C slave device.
[0001.598] E> I2C: slave not found in slaves.
[0001.602] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.609] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.615] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.625] E> eeprom: Failed to read I2C slave device
[0001.629] I> Eeprom read failed 0x3526070d
[0001.635] I> Find /i2c@3160000's alias i2c0
[0001.639] I> Reading eeprom i2c=0 address=0x50
[0001.643] E> I2C: slave not found in slaves.
[0001.648] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.655] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.661] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.671] E> eeprom: Failed to read I2C slave device
[0001.675] I> Eeprom read failed 0x3526070d
[0001.681] I> Find /i2c@3180000's alias i2c2
[0001.685] I> Reading eeprom i2c=2 address=0x54
[0001.690] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.694] C> GPIO driver for chip_id 0x2 could not be found
[0001.700] E> cam_eeprom_read: Can't get gpio driver
[0001.704] I> Eeprom read failed 0x4d4d000d
[0001.708] I> Reading eeprom i2c=2 address=0x57
[0001.713] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.717] C> GPIO driver for chip_id 0x2 could not be found
[0001.723] E> cam_eeprom_read: Can't get gpio driver
[0001.727] I> Eeprom read failed 0x4d4d000d
[0001.731] I> create_pm_ids: id: 3310-1000-B02-E, len: 15
[0001.736] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.761] E> cannot find any other nvdisp nodes
[0001.765] E> no valid display unit config found in dtb
[0001.771] W> display init failed
[0001.774] initializing target
[ 7.486852] random: crng init done
[ 7.490272] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.571004] tegra-i2c c240000.i2c: no acknowledge from address 0x69
[ 7.577343] bmi160 1-0069: bmi_i2c_rd ERR: 0x00
[ 7.584980] bmi160 1-0069: bmi_init _id_i2c ERR
[ 8.522864] vdd-1v8: voltage operation not allowed
[ 8.527685] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.555089] vdd-1v8: voltage operation not allowed
[ 8.559904] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.583870] vdd-1v8: voltage operation not allowed
[ 8.588675] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.597686] vdd-1v8: voltage operation not allowed
[ 8.602507] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.713939] vdd-1v8: voltage operation not allowed
[ 8.718830] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.727824] vdd-1v8: voltage operation not allowed
[ 8.732628] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.740759] vdd-1v8: voltage operation not allowed
[ 8.745564] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
We did the configuration of the display as in JetPack 3.3:
host1x {
nvdisplay@15200000 {
status = "okay";
nvidia,dc-or-node = "/host1x/sor";
sor {
bootloader-status = "okay";
status = "okay";
dp-display {
status = "okay";
dpaux@155c0000 {
status = "okay";
dpaux@15040000 {
bootloader-status = "disabled";
nvdisplay@15210000 {
sor1 {
dp-display {
hdmi-display {
nvdisplay@15220000 {
plugin-manager {
/delete-node/ fragment-e3320-dp;
/delete-node/ fragment-e3320-a00@1;
/delete-node/ fragment-e3320-a01@1;
Could you provide us a DTB file for using the DP as primary display as in JetPack 3.3?
Do we need to configure something else to make DP work?
Thank you for your help.
Kind regards
