Jetson TX1 Main Connector Informations
Dear all,
I would like to know if there is a way to have technical informations about the main connector of the Jetson TX1. I mean electronic informations.
The goal is to connect the Jetson TX1 on a specific PCB to obtain an embedded platform.
Thank you for your help and support.
Regards,
Hi Christophe, please refer to the Jetson TX1 Module Data Sheet and the Jetson TX1 OEM Design Guide, which contain the connector pinout, signalling/routing guidelines, and electromechanical specifications.
You may also be interested in the Jetson TX1 Developer Kit Carrier Board Design Files, which contains the reference design for the devkit carrier board that you can modify for your own purposes.
Hi Dusty,
Thanks a lot for the informations.
Regards,
