JETSON TX1/TX2 Hardware Question
I am going to design a carrier board for TX1/TX2. There is a suggested mating connector for the module 400 pin interface connector in the TX1/TX2 datasheet. However the part number of the connector on the module itself is not mentioned in the datasheet and in the OEM carrier design guide. I need to know the part number of the connector on the module to determine the required spacer/stand off to be used between the module and the carrier board. Where can i get this information?
The connector info is contained in page 42 of module datasheet, P/N is SAMTEC-SEAF-50-05-S-08-02-A-K
Hello, the information mentioned at the page 42 of datasheet is the connector on the module, what im looking for is the mating connector to be used on the carrier board. I couldnt find any information regarding mating connector in any documents.
“I need to know the part number of the connector on the module”…
Anyway, please refer to this topic: [url]https://devtalk.nvidia.com/default/topic/1003490/samtec-400pin-board-to-board-connector/[/url]
