We want to connect our sensor module to TX2 development board with an adapter(4-lane CSI). We have designed the schematic for same and is placed at below link.
https://drive.google.com/file/d/1c6P80ytXo4bDNkWieolOdAEiTCQ1mtLH/view?usp=sharing
Could someone please review the schematic and pinout of P1?
Also “Jetson_Camera_Module_Hardware_Design_Guide.pdf” doc suggest to use “QTH-060-01-F(H)-D-A-x” as mating connector part however we have used “QTH-060-01-L-D-A” as the mating part to interface it with TX2 development board. Please confirm if this is okay.
We have an another query related to board size dimension wrt the mounting holes. Figure 8-1. Recommended Interposer Module Outline in “Jetson_Camera_Module_Hardware_Design_Guide.pdf”.Here the width of PCB is 40mm and the mounting hole to board edge is 4mm both the side. So distance between two mounting hole should not be 32mm? The fig shows a dimension of 32.2mm. As shown at below link
https://drive.google.com/file/d/1l5a8M_TayI6WxcSO4h5Mn1EINNT_Xe0p/view?usp=sharing
Please confirm.
Thanks,
Sanjeev
