I’m working with a Jetson TX1 and I want to run multiple independent displays.
By referring to the TX1 Carrier Board specification, I have narrowed it down to here.
3.2
Display Expansion Connector
The Jetson TX1 carrier board includes a 120-pin (2x60, 0.5 mm pitch) Display Expansion Connector (J23). The connector used on the Carrier board is a Samtec QSH-060-01-H-D -A. The mating connector is a Samtec QTH -060-01-H-D -A. The displayexpansion connector
includes interface options for an embedded display and touch controller including
DSI 2 x4
eDP
eDP HPD
eDP AUX
LCD BL EN/PWM
LCD EN/TE/BIAS EN
SPI0, SPI2
I2C_GP1
Touch INT/RST/CLK
Display control
My question is this.
Can the Jetson TX1 J23 coupled with a DSI to HDMI converter such as
http://www.analog.com/media/en/technical-documentation/data-sheets/ADV7533.pdf
directly run an external HD display?
Or are there software backend modifications that need to be done?
According to NVIDIA documentation, the Jetson TX1 is capable of running multiple displays.
Thanks in advance.
