I know that J23 connector is providing some interfaces to connect a display device. Does this also mean that the underlying software is supporting the usage of multiple displays?
And does anybody know a solution to connect to J23 or does a Carrier Board exists which exposes the additional display connection as HDMI, eDP etc?
I believe the additional connection is intended for eDP. I’m not sure what eDP support there is in the Linux kernel, but I know eDP hardware has been successfully created using this connection.
thank you for your reply.
I see that they are exposing eDP and DSI over this connector. My personal problem is that I am not capable to create such a connection with the given mate connector. I mean I could by the connector but then would be lost with it ;)
