Is there a reference schematic for DP0 on a custom carrier?
My custom schematic seems not to work: The driver gets RX_ERROR on the AUX lines.
I found 2 documents referring to P2597, but both of them do not have a reference schematic on how to connect a DisplayPort Monitor to the TX2.
Here is our schematic. Would you mind confirming the correctness?
Do you have device tree where DP0 is activated as the standard monitor instead of HDMI?
Please refer to the TX2 OEM Design Guide in DLC. There is DP/HDMI design example for your reference.
