I tried to read and run the IP Camera input with OpenCV on Jetson TX2 using a python script. While the code gave a memory leak of around 38 MB on TX2, the same code on the CPU did not give a considerable memory leak in the same running time. What could be the solution to this?
WayneWWW
2
priyam27mzb,
Could you share your code? Could you try to use on-board camera or usb camera to observe same leakage?
Related topics
| multimedia API 。I find memory leak | 8 | 1126 | August 31, 2017 | |
| Jetson Nano cv2 VideoCapture Memory Leak | 2 | 1266 | October 15, 2021 | |
| Extremely high memory leak with OpenCV video capture | 6 | 4759 | September 5, 2021 | |
| Memory leak in Unity desktop - JetPack 2.2.1 | 2 | 852 | August 31, 2016 | |
| Memory leak jetson-nano-jp46-sd-card-image | 3 | 697 | October 15, 2021 | |
| Kernel memory leak(s) with simple nvarguscamerasrc pipeline | 1 | 89 | March 26, 2025 | |
| Does Jetson-TX2 RJ28.3 fixed Memory leak When used V4L2_MEMORY_MMAP | 1 | 482 | May 13, 2019 | |
| Possible memory leak using opencv VideoCapture with gstreamer backend | 2 | 407 | February 8, 2023 | |
| Encoder multi media api memory leak | 2 | 73 | January 23, 2025 | |
| Possible memory leak using opencv VideoCapture with gstreamer backend | 6 | 1621 | February 8, 2023 |
