I wonder if this module has onboard Bluetooth capabilities or if I would need to add a Bluetooth card and antennas. Thank you!
Hello @1justwatching23 and welcome to the NVIDIA developer forums!
The plain TX2 NX module does not have WiFi/BT support built-in.
But usually, if you can still get it, the module is distributed as part of a development kit that has a slot with a preinstalled M.2 Wifi/BT card.
I hope this helps. If you have more Jetson related questions I highly recommend our dedicated Jetson categories here on our forums!
