We are designing a carrier board for Xavier NX. We are looking for a WIFI/BT Soc to connect to Xavier NX over PCI interface (SDIO will be used for SD card) with minimum software development effort (kernel support).
Can you advise?
Can you advise?
Hi, we have no such recommended ones. For Xavier NX, the PCIe port is standard, there is port design guideline in the OEM DG in DLC. You can search for the fit Soc and check with vendor for more detail info.
I’m using the intel module on Jetson Nano, 2.4/5Ghz and bluetooth. Should work with NX since its the same dev board?
Thank you, Phil and Trumany.
